Serial interface not working!
cbow81142
Community Member
Hi. I just recently bought a new Cisco 2611 for my home lab and am having trouble getting the serial port to work. I have tried multiple things such as erase startup, switching the cables to rule them out, and even changing IP addresses but none worked. The port may be dead but I thought I would see if anyone could see anything else to try before I replaced it. Here is the output I am getting:
Router#show controllers
Interface Serial0/0
Hardware is PowerQUICC MPC860
DCE 530, clock rate 64000
idb at 0x84C4310C, driver data structure at 0x84C4A830
SCC Registers:
General [GSMR]=0x2:0x00000030, Protocol-specific [PSMR]=0x8
Events [SCCE]=0x0300, Mask [SCCM]=0x001F, Status [SCCS]=0x03
Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E
Interrupt Registers:
Config [CICR]=0x00367F80, Pending [CIPR]=0x00000000
Mask   [CIMR]=0x40204000, In-srv  [CISR]=0x00000000
Command register [CR]=0x600
Port A [PADIR]=0x0100, [PAPAR]=0xFFFF
       [PAODR]=0x0000, [PADAT]=0xF6FF
Port B [PBDIR]=0x0180F, [PBPAR]=0x0000E
       [PBODR]=0x00000, [PBDAT]=0x3E7FD
Port C [PCDIR]=0x00C, [PCPAR]=0x000
       [PCSO]=0x020,  [PCDAT]=0xFF2, [PCINT]=0x00F
Receive Ring
        rmd(680126B0): status 9000 length 60C address 7CEAD24
        rmd(680126B8): status 9000 length 60C address 7CEA6A4
        rmd(680126C0): status 9000 length 60C address 7CEA024
        rmd(680126C8): status 9000 length 60C address 7D09764
Router#show int serial0/0
Serial0/0 is down, line protocol is down
  Hardware is PowerQUICC Serial
  Internet address is 192.168.1.2/24
  MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  Keepalive set (10 sec)
  Last input never, output never, output hang never
  Last clearing of "show interface" counters 00:31:45
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 47 interface resets
     0 unknown protocol drops
     0 carrier transitions
     DCD=up  DSR=up  DTR=down  RTS=down  CTS=up
Router#debug serial int
Serial network interface debugging is on
Router#
*Mar  1 01:15:50.410: Serial0/0: attempting to restart
*Mar  1 01:16:20.412: Serial0/0: attempting to restart
*Mar  1 01:16:50.413: Serial0/0: attempting to restart
*Mar  1 01:17:20.414: Serial0/0: attempting to restart
*Mar  1 01:17:50.415: Serial0/0: attempting to restart
*Mar  1 01:18:20.416: Serial0/0: attempting to restart
*Mar  1 01:18:50.417: Serial0/0: attempting to restart
*Mar  1 01:19:20.419: Serial0/0: attempting to restart
*Mar  1 01:19:50.420: Serial0/0: attempting to restart
*Mar  1 01:20:20.421: Serial0/0: attempting to restart
*Mar  1 01:20:50.450: Serial0/0: attempting to restart
Router#show run
Building configuration...
Current configuration : 733 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
interface FastEthernet0/0
ip address 10.0.0.2 255.255.255.0
duplex auto
speed auto
interface Serial0/0
ip address 192.168.1.2 255.255.255.0
no fair-queue
clock rate 64000
ip forward-protocol nd
ip http server
no ip http secure-server
control-plane
line con 0
line aux 0
line vty 0 4
end
Any help is greatly appreciated! Thanks!
6 Replies 6
cadet alain
Serial0/0 is down, Line Protocol is down
This indicates that the DTE router is down or a media problem.
Regards.
Alain
Reza Sharifi
The cable needs to be V.35.
Is this back-to-back V.35 cable (60Pins)?
Giuseppe Larosa
Hello Cory,
the clock rate command for OSI Layer 1 DCE operations has to be given on the router that has the DCE cable directly connected to it.
This looks like to be your case
Here, what we see is that all state leads that should come from the DTE device are down
For this the interface is kept down/down and attempts to restart from time to time.
I suppose you have another router with a serial interface and a DTE cable interconnected to this router.
The V.35 DCE (female) to DTE (male) connection requires that you close completely the screws or it fails to build the electrical connection. There must be no gap left between the two connectors they must touch each other.
see
Hope to help
Giuseppe
This is the serial cable I am using. Yes I am connecting it to another router. I have tried both ways but currently have the DCE end plugged in to the port I suspect is not working. I have narrowed it down to this port because when I use the serial port on the second router connected to a third, it works.
I have resolved the issue. I took the interface out and simply put it back in and now it works. Thanks for your help everyone!
Hello Cory,
May I ask you what is the part number of the cable you are using ?
Edit:
good that you have solved you have reseated the serial interface in the router .
Hope to help
Giuseppe
