Server having 2 NIC and both are in same vlan not able to communicate with other server in same VLAN
digambar_giri
Hello Team,
I have connected server having 2 NIC on the switch ws-c3750x-24
10.1.0.0 series is part of vlan 100
and 192.168.2.0 is part of vlan 116
Not able to ping these server each other. Please suggest ,
her is the configuration.
Building configuration...
Current configuration : 3507 bytes
! Last configuration change at 03:55:59 UTC Sun Apr 18 1993
version 12.2
no service pad
hostname switch
boot-start-marker
boot-end-marker
enable secret 5 $1$jYAL$A6yt86EmEG4hQs8C.Ue47.
no aaa new-model
switch 1 provision ws-c3750x-24
system mtu routing 1500
ip routing
--More--                           !
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet0
no ip address
no ip route-cache cef
no ip route-cache
--More--                           interface GigabitEthernet1/0/1
switchport access vlan 100
switchport mode access
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
switchport access vlan 116
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
--More--                           interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
--More--                           interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
--More--                           interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
no switchport
ip address 192.168.164.62 255.255.255.252
interface GigabitEthernet1/0/21
no switchport
ip address 192.168.164.198 255.255.255.252
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
switchport trunk allowed vlan 100,116
switchport mode trunk
interface GigabitEthernet1/0/24
no switchport
ip address 30.30.30.2 255.255.255.252
interface GigabitEthernet1/1/1
--More--                           interface GigabitEthernet1/1/2
interface GigabitEthernet1/1/3
interface GigabitEthernet1/1/4
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface Vlan1
no ip address
interface Vlan100
ip address 10.1.0.1 255.255.0.0
router bgp 65000
bgp log-neighbor-changes
network 10.1.0.0 mask 255.255.0.0
redistribute connected
neighbor 192.168.164.61 remote-as ******
neighbor 192.168.164.61 timers 20 30
neighbor 192.168.164.61 allowas-in 1
neighbor 192.168.164.61 weight 200
neighbor 192.168.164.197 remote-as ******
neighbor 192.168.164.197 timers 20 30
neighbor 192.168.164.197 allowas-in 1
neighbor 192.168.164.197 weight 20
no auto-summary
ip http server
ip http secure-server
logging esm config
line con 0
line vty 0 4
password cisco
login
line vty 5 15
login
end
5 Replies 5
digambar_giri
            Wrongly i have pasted incomplete configuration, here is the complete configuration
version 12.2
no service pad
hostname switch
boot-start-marker
boot-end-marker
no aaa new-model
ip routing
--More--                           !
no ip address
no ip route-cache
no switchport
no switchport
no switchport
interface Vlan1
no ip address
interface Vlan100
interface Vlan116
ip address 192.168.2.1 255.255.255.0
router bgp 65000
no auto-summary
ip http server
logging esm config
line con 0
line vty 0 4
password cisco
login
line vty 5 15
login
end
could you please post sh ip route ?
Just for clarification. In your diagram there are just two servers with subnet 192.168.2.0/24.  Are this servers able to ping default gateway 192.168.2.1 ?
Also, could you please explain why network 10.1.0.0(server net) is in BGP routing? Is there some reason fo this?
Jan
Hello Jan,
Servers are in BGP because they will need to be accesaaable from branch location. this is MPLS setup.
my servers are not able to ping gateways 192.168.2.1
But problem is when i put
Port 4 and port 6 into VLAN 116 my DB01 and DB01 are not able to ping each other and also they can not able to ping SAN storage.
Sho ip route
switch#sho ip route
Codes: L - local, C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route, H - NHRP, l - LISP
       + - replicated route, % - next hop override
Gateway of last resort is not set
      10.0.0.0/8 is variably subnetted, 280 subnets, 3 masks
C        10.1.0.0/16 is directly connected, Vlan100
L        10.1.0.1/32 is directly connected, Vlan100
B        10.3.1.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.3.2.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.3.3.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.3.4.0/24 [20/0] via 192.168.164.61, 00:21:03
B        10.3.5.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.3.6.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.3.7.0/24 [20/0] via 192.168.164.61, 06:28:34
B        10.3.8.0/24 [20/0] via 192.168.164.61, 02:31:33
B        10.3.9.0/24 [20/0] via 192.168.164.61, 00:00:20
B        10.3.10.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.3.11.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.3.12.0/24 [20/0] via 192.168.164.61, 01:45:05
B        10.3.13.0/24 [20/0] via 192.168.164.61, 05:40:52
B        10.3.14.0/24 [20/0] via 192.168.164.61, 22:12:35
B        10.4.1.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.4.2.0/24 [20/0] via 192.168.164.61, 22:12:35
B        10.4.3.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.4.4.0/24 [20/0] via 192.168.164.61, 22:12:35
B        10.4.5.0/24 [20/0] via 192.168.164.61, 22:12:35
B        10.4.6.0/24 [20/0] via 192.168.164.61, 00:06:46
B        10.4.7.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.4.8.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.4.9.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.4.10.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.4.11.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.4.12.0/24 [20/0] via 192.168.164.61, 00:08:54
B        10.4.13.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.4.14.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.4.15.0/24 [20/0] via 192.168.164.61, 00:45:09
B        10.4.16.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.4.17.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.18.0/24 [20/0] via 192.168.164.61, 19:39:55
B        10.4.19.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.20.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.21.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.23.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.24.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.25.0/24 [20/0] via 192.168.164.61, 01:14:43
B        10.4.26.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.27.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.28.0/24 [20/0] via 192.168.164.61, 02:28:44
B        10.4.29.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.30.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.31.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.51.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.52.0/24 [20/0] via 192.168.164.61, 00:14:47
B        10.4.53.0/24 [20/0] via 192.168.164.61, 19:39:55
B        10.4.54.0/24 [20/0] via 192.168.164.61, 00:09:01
B        10.4.55.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.56.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.57.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.58.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.59.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.60.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.61.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.62.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.63.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.64.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.65.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.66.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.67.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.68.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.91.0/24 [20/0] via 192.168.164.61, 00:18:11
B        10.4.92.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.93.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.94.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.95.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.96.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.98.0/24 [20/0] via 192.168.164.61, 05:30:41
B        10.4.101.0/24 [20/0] via 192.168.164.61, 01:21:39
B        10.4.102.0/24 [20/0] via 192.168.164.61, 00:25:51
B        10.4.103.0/24 [20/0] via 192.168.164.61, 00:27:24
B        10.4.104.0/24 [20/0] via 192.168.164.61, 06:22:22
B        10.4.105.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.106.0/24 [20/0] via 192.168.164.61, 03:01:41
B        10.4.107.0/24 [20/0] via 192.168.164.61, 19:39:55
B        10.4.109.0/24 [20/0] via 192.168.164.61, 00:47:29
B        10.4.110.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.111.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.112.0/24 [20/0] via 192.168.164.61, 04:15:12
B        10.4.121.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.122.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.123.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.124.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.125.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.126.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.127.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.128.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.129.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.130.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.131.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.132.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.133.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.134.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.135.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.136.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.137.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.138.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.139.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.151.0/24 [20/0] via 192.168.164.61, 00:23:14
B        10.4.152.0/24 [20/0] via 192.168.164.61, 06:13:46
B        10.4.153.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.154.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.155.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.156.0/24 [20/0] via 192.168.164.61, 05:18:52
B        10.4.157.0/24 [20/0] via 192.168.164.61, 00:13:42
B        10.4.158.0/24 [20/0] via 192.168.164.61, 00:25:16
B        10.4.159.0/24 [20/0] via 192.168.164.61, 03:21:06
B        10.4.160.0/24 [20/0] via 192.168.164.61, 00:33:53
B        10.4.161.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.162.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.163.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.164.0/24 [20/0] via 192.168.164.61, 03:10:35
B        10.4.165.0/24 [20/0] via 192.168.164.61, 05:35:25
B        10.4.166.0/24 [20/0] via 192.168.164.61, 00:39:15
B        10.4.167.0/24 [20/0] via 192.168.164.61, 05:41:27
B        10.4.168.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.169.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.170.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.171.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.172.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.173.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.174.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.181.0/24 [20/0] via 192.168.164.61, 03:11:57
B        10.4.182.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.183.0/24 [20/0] via 192.168.164.61, 19:39:43
B        10.4.184.0/24 [20/0] via 192.168.164.61, 01:47:44
B        10.4.185.0/24 [20/0] via 192.168.164.61, 00:03:51
B        10.4.186.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.187.0/24 [20/0] via 192.168.164.61, 19:39:18
B        10.4.188.0/24 [20/0] via 192.168.164.61, 19:39:55
B        10.4.189.0/24 [20/0] via 192.168.164.61, 06:28:30
B        10.4.190.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.191.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.192.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.193.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.194.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.196.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.197.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.198.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.199.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.200.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.201.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.202.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.203.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.211.0/24 [20/0] via 192.168.164.61, 02:31:34
B        10.4.212.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.213.0/24 [20/0] via 192.168.164.61, 02:31:38
B        10.4.214.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.215.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.216.0/24 [20/0] via 192.168.164.61, 19:58:17
B        10.4.217.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.218.0/24 [20/0] via 192.168.164.61, 19:58:17
B        10.4.219.0/24 [20/0] via 192.168.164.61, 00:48:39
B        10.4.220.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.221.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.222.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.223.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.231.0/24 [20/0] via 192.168.164.61, 03:44:05
B        10.4.232.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.233.0/24 [20/0] via 192.168.164.61, 01:05:07
B        10.4.234.0/24 [20/0] via 192.168.164.61, 00:00:26
B        10.4.235.0/24 [20/0] via 192.168.164.61, 10:53:20
B        10.4.236.0/24 [20/0] via 192.168.164.61, 00:20:10
B        10.4.237.0/24 [20/0] via 192.168.164.61, 10:53:20
B        10.4.238.0/24 [20/0] via 192.168.164.61, 00:57:59
B        10.4.239.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.240.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.241.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.242.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.243.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.244.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.245.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.246.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.4.254.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.1.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.2.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.3.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.4.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.5.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.6.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.7.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.8.0/24 [20/0] via 192.168.164.61, 04:31:36
B        10.5.9.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.10.0/24 [20/0] via 192.168.164.61, 19:39:43
B        10.5.11.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.12.0/24 [20/0] via 192.168.164.61, 19:39:59
B        10.5.13.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.14.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.15.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.16.0/24 [20/0] via 192.168.164.61, 04:35:19
B        10.5.17.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.18.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.19.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.20.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.21.0/24 [20/0] via 192.168.164.61, 04:10:12
B        10.5.23.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.24.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.25.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.31.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.32.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.34.0/24 [20/0] via 192.168.164.61, 14:32:55
B        10.5.35.0/24 [20/0] via 192.168.164.61, 01:33:39
B        10.5.36.0/24 [20/0] via 192.168.164.61, 00:26:05
B        10.5.37.0/24 [20/0] via 192.168.164.61, 00:07:17
B        10.5.38.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.39.0/24 [20/0] via 192.168.164.61, 03:05:26
B        10.5.40.0/24 [20/0] via 192.168.164.61, 01:32:59
B        10.5.41.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.43.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.44.0/24 [20/0] via 192.168.164.61, 06:03:06
B        10.5.45.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.46.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.47.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.48.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.49.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.50.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.51.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.52.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.53.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.54.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.55.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.56.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.57.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.58.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.59.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.60.0/24 [20/0] via 192.168.164.61, 00:14:23
B        10.5.61.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.62.0/24 [20/0] via 192.168.164.61, 04:04:06
B        10.5.63.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.64.0/24 [20/0] via 192.168.164.61, 19:39:55
B        10.5.65.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.66.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.67.0/24 [20/0] via 192.168.164.61, 19:39:55
B        10.5.81.0/24 [20/0] via 192.168.164.61, 00:59:57
B        10.5.82.0/24 [20/0] via 192.168.164.61, 03:24:35
B        10.5.83.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.84.0/24 [20/0] via 192.168.164.61, 00:17:37
B        10.5.85.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.86.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.87.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.88.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.89.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.90.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.91.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.92.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.93.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.94.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.95.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.96.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.111.0/24 [20/0] via 192.168.164.61, 00:25:35
B        10.5.112.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.113.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.114.0/24 [20/0] via 192.168.164.61, 06:22:55
B        10.5.115.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.116.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.117.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.118.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.119.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.120.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.121.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.122.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.123.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.124.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.125.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.141.0/24 [20/0] via 192.168.164.61, 06:31:13
B        10.5.142.0/24 [20/0] via 192.168.164.61, 22:12:36
B        10.5.143.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.144.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.145.0/24 [20/0] via 192.168.164.61, 02:56:47
B        10.5.146.0/24 [20/0] via 192.168.164.61, 05:11:41
B        10.5.147.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.148.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.149.0/24 [20/0] via 192.168.164.61, 02:02:33
B        10.5.150.0/24 [20/0] via 192.168.164.61, 19:39:55
B        10.5.151.0/24 [20/0] via 192.168.164.61, 19:39:51
B        10.5.152.0/24 [20/0] via 192.168.164.61, 22:12:37
B        10.5.153.0/24 [20/0] via 192.168.164.61, 22:12:37
B     192.168.0.0/24 [20/0] via 192.168.164.61, 22:12:37
      192.168.2.0/24 is variably subnetted, 2 subnets, 2 masks
C        192.168.2.0/24 is directly connected, Vlan116
L        192.168.2.1/32 is directly connected, Vlan116
      192.168.13.0/30 is subnetted, 11 subnets
B        192.168.13.24 [20/0] via 192.168.164.61, 22:12:36
B        192.168.13.28 [20/0] via 192.168.164.61, 22:12:36
B        192.168.13.32 [20/0] via 192.168.164.61, 22:12:36
B        192.168.13.184 [20/0] via 192.168.164.61, 22:12:36
B        192.168.13.192 [20/0] via 192.168.164.61, 22:12:36
B        192.168.13.196 [20/0] via 192.168.164.61, 22:12:36
B        192.168.13.200 [20/0] via 192.168.164.61, 22:12:36
B        192.168.13.208 [20/0] via 192.168.164.61, 22:12:36
B        192.168.13.216 [20/0] via 192.168.164.61, 22:12:36
B        192.168.13.220 [20/0] via 192.168.164.61, 22:12:36
B        192.168.13.224 [20/0] via 192.168.164.61, 22:12:36
B     192.168.15.0/24 [20/0] via 192.168.164.61, 22:12:38
      192.168.111.0/30 is subnetted, 15 subnets
B        192.168.111.32 [20/0] via 192.168.164.61, 22:12:37
B        192.168.111.36 [20/0] via 192.168.164.61, 22:12:38
B        192.168.111.40 [20/0] via 192.168.164.61, 22:12:38
B        192.168.111.44 [20/0] via 192.168.164.61, 22:12:38
B        192.168.111.48 [20/0] via 192.168.164.61, 22:12:37
B        192.168.111.52 [20/0] via 192.168.164.61, 22:12:38
B        192.168.111.56 [20/0] via 192.168.164.61, 22:12:37
B        192.168.111.60 [20/0] via 192.168.164.61, 22:12:38
B        192.168.111.64 [20/0] via 192.168.164.61, 22:12:38
B        192.168.111.68 [20/0] via 192.168.164.61, 22:12:38
B        192.168.111.76 [20/0] via 192.168.164.61, 22:12:38
B        192.168.111.80 [20/0] via 192.168.164.61, 22:12:38
B        192.168.111.84 [20/0] via 192.168.164.61, 22:12:38
B        192.168.111.88 [20/0] via 192.168.164.61, 22:12:38
B        192.168.111.92 [20/0] via 192.168.164.61, 22:12:37
      192.168.123.0/30 is subnetted, 1 subnets
B        192.168.123.0 [20/0] via 192.168.164.61, 22:12:37
      192.168.131.0/30 is subnetted, 3 subnets
B        192.168.131.84 [20/0] via 192.168.164.61, 22:12:37
B        192.168.131.88 [20/0] via 192.168.164.61, 22:12:37
B        192.168.131.92 [20/0] via 192.168.164.61, 22:12:37
      192.168.142.0/30 is subnetted, 3 subnets
B        192.168.142.28 [20/0] via 192.168.164.61, 22:12:37
B        192.168.142.36 [20/0] via 192.168.164.61, 22:12:37
B        192.168.142.192 [20/0] via 192.168.164.61, 22:12:38
      192.168.148.0/30 is subnetted, 8 subnets
B        192.168.148.224 [20/0] via 192.168.164.61, 22:12:37
B        192.168.148.228 [20/0] via 192.168.164.61, 22:12:37
B        192.168.148.232 [20/0] via 192.168.164.61, 22:12:37
B        192.168.148.236 [20/0] via 192.168.164.61, 22:12:37
B        192.168.148.240 [20/0] via 192.168.164.61, 22:12:37
B        192.168.148.244 [20/0] via 192.168.164.61, 22:12:37
B        192.168.148.248 [20/0] via 192.168.164.61, 22:12:37
B        192.168.148.252 [20/0] via 192.168.164.61, 22:12:37
      192.168.154.0/30 is subnetted, 3 subnets
B        192.168.154.36 [20/0] via 192.168.164.61, 22:12:37
B        192.168.154.64 [20/0] via 192.168.164.61, 22:12:37
B        192.168.154.208 [20/0] via 192.168.164.61, 22:12:37
      192.168.159.0/30 is subnetted, 10 subnets
B        192.168.159.56 [20/0] via 192.168.164.61, 22:12:37
B        192.168.159.60 [20/0] via 192.168.164.61, 22:12:38
B        192.168.159.64 [20/0] via 192.168.164.61, 22:12:37
B        192.168.159.68 [20/0] via 192.168.164.61, 22:12:37
B        192.168.159.72 [20/0] via 192.168.164.61, 22:12:38
B        192.168.159.76 [20/0] via 192.168.164.61, 22:12:38
B        192.168.159.80 [20/0] via 192.168.164.61, 22:12:37
B        192.168.159.84 [20/0] via 192.168.164.61, 22:12:37
B        192.168.159.92 [20/0] via 192.168.164.61, 22:12:37
B        192.168.159.96 [20/0] via 192.168.164.61, 22:12:37
      192.168.164.0/24 is variably subnetted, 11 subnets, 2 masks
B        192.168.164.4/30 [20/0] via 192.168.164.61, 22:12:37
B        192.168.164.8/30 [20/0] via 192.168.164.61, 22:12:37
C        192.168.164.60/30 is directly connected, GigabitEthernet1/0/20
L        192.168.164.62/32 is directly connected, GigabitEthernet1/0/20
B        192.168.164.160/30 [20/0] via 192.168.164.61, 22:12:37
B        192.168.164.164/30 [20/0] via 192.168.164.61, 22:12:37
B        192.168.164.168/30 [20/0] via 192.168.164.61, 22:12:37
B        192.168.164.172/30 [20/0] via 192.168.164.61, 22:12:37
B        192.168.164.184/30 [20/0] via 192.168.164.61, 22:12:37
C        192.168.164.196/30 is directly connected, GigabitEthernet1/0/21
L        192.168.164.198/32 is directly connected, GigabitEthernet1/0/21
      192.168.172.0/30 is subnetted, 1 subnets
B        192.168.172.228 [20/0] via 192.168.164.61, 22:12:38
      192.168.177.0/30 is subnetted, 1 subnets
B        192.168.177.0 [20/0] via 192.168.164.61, 22:12:37
      192.168.181.0/30 is subnetted, 7 subnets
B        192.168.181.228 [20/0] via 192.168.164.61, 22:12:37
B        192.168.181.232 [20/0] via 192.168.164.61, 22:12:37
B        192.168.181.236 [20/0] via 192.168.164.61, 22:12:37
B        192.168.181.240 [20/0] via 192.168.164.61, 22:12:37
B        192.168.181.244 [20/0] via 192.168.164.61, 22:12:37
B        192.168.181.248 [20/0] via 192.168.164.61, 22:12:37
B        192.168.181.252 [20/0] via 192.168.164.61, 22:12:37
      192.168.182.0/30 is subnetted, 59 subnets
B        192.168.182.20 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.24 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.28 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.32 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.36 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.40 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.44 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.48 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.52 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.56 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.60 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.64 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.68 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.72 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.76 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.80 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.84 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.88 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.92 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.96 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.100 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.104 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.108 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.112 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.116 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.120 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.124 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.128 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.132 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.136 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.140 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.144 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.148 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.152 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.156 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.160 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.164 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.168 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.172 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.176 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.180 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.184 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.188 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.192 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.196 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.200 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.204 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.208 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.212 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.216 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.220 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.224 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.228 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.232 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.236 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.240 [20/0] via 192.168.164.61, 22:12:37
B        192.168.182.244 [20/0] via 192.168.164.61, 22:12:38
B        192.168.182.248 [20/0] via 192.168.164.61, 22:12:38
B        192.168.182.252 [20/0] via 192.168.164.61, 22:12:38
      192.168.183.0/30 is subnetted, 44 subnets
B        192.168.183.0 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.4 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.8 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.12 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.16 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.20 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.24 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.28 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.32 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.36 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.40 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.44 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.48 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.64 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.68 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.72 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.76 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.80 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.84 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.88 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.92 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.96 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.100 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.104 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.108 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.112 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.116 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.120 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.124 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.128 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.132 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.136 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.140 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.144 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.148 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.152 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.156 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.160 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.164 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.168 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.172 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.208 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.212 [20/0] via 192.168.164.61, 22:12:38
B        192.168.183.216 [20/0] via 192.168.164.61, 22:12:38
      192.168.185.0/30 is subnetted, 9 subnets
B        192.168.185.8 [20/0] via 192.168.164.61, 22:12:38
B        192.168.185.44 [20/0] via 192.168.164.61, 22:12:39
B        192.168.185.48 [20/0] via 192.168.164.61, 22:12:38
B        192.168.185.52 [20/0] via 192.168.164.61, 22:12:38
B        192.168.185.184 [20/0] via 192.168.164.61, 22:12:39
B        192.168.185.192 [20/0] via 192.168.164.61, 22:12:39
B        192.168.185.200 [20/0] via 192.168.164.61, 22:12:39
B        192.168.185.216 [20/0] via 192.168.164.61, 06:28:37
B        192.168.185.248 [20/0] via 192.168.164.61, 22:12:38
      192.168.188.0/30 is subnetted, 4 subnets
B        192.168.188.0 [20/0] via 192.168.164.61, 22:12:38
B        192.168.188.4 [20/0] via 192.168.164.61, 22:12:38
B        192.168.188.156 [20/0] via 192.168.164.61, 22:12:38
B        192.168.188.188 [20/0] via 192.168.164.61, 22:12:38
      192.168.189.0/30 is subnetted, 3 subnets
B        192.168.189.84 [20/0] via 192.168.164.61, 22:12:38
B        192.168.189.176 [20/0] via 192.168.164.61, 22:12:38
B        192.168.189.180 [20/0] via 192.168.164.61, 22:12:39
      192.168.193.0/30 is subnetted, 20 subnets
B        192.168.193.140 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.152 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.156 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.160 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.164 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.168 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.172 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.176 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.180 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.196 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.200 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.204 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.208 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.212 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.216 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.220 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.224 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.228 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.232 [20/0] via 192.168.164.61, 22:12:38
B        192.168.193.236 [20/0] via 192.168.164.61, 22:12:38
      192.168.194.0/30 is subnetted, 1 subnets
B        192.168.194.200 [20/0] via 192.168.164.61, 22:12:38
      192.168.199.0/30 is subnetted, 18 subnets
B        192.168.199.0 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.4 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.8 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.12 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.16 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.20 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.24 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.28 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.32 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.36 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.40 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.44 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.68 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.72 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.116 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.120 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.128 [20/0] via 192.168.164.61, 22:12:38
B        192.168.199.252 [20/0] via 192.168.164.61, 22:12:38
      192.168.237.0/30 is subnetted, 30 subnets
B        192.168.237.132 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.136 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.140 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.144 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.148 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.152 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.156 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.160 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.164 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.168 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.172 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.176 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.180 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.184 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.192 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.196 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.200 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.204 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.208 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.212 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.216 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.220 [20/0] via 192.168.164.61, 22:12:38
B        192.168.237.224 [20/0] via 192.168.164.61, 22:12:39
B        192.168.237.228 [20/0] via 192.168.164.61, 22:12:39
B        192.168.237.232 [20/0] via 192.168.164.61, 22:12:39
B        192.168.237.236 [20/0] via 192.168.164.61, 22:12:39
B        192.168.237.240 [20/0] via 192.168.164.61, 22:12:39
B        192.168.237.244 [20/0] via 192.168.164.61, 22:12:39
B        192.168.237.248 [20/0] via 192.168.164.61, 22:12:39
B        192.1.237.252 [20/0] via 192.168.164.61, 22:12:39
      192.168.248.0/30 is subnetted, 1 subnets
B        192.168.248.16 [20/0] via 192.168.164.61, 22:12:39
Do you see the MAC Addresses in the MAC-address table and ARP table of the 3750 switch?
We had a similar issue and the proble was that the windows FW was blocking ICMP.
Best regards,
Vlad
Mahadev Patil
Hi digambar_giri
You can create Ether-Channel between Cisco 3750 and your all Servers. ether-channel mode L2.
Mahadev
