Set a port to trunk mode on SG200-26??
stevegrosz
I am trying to connect my SG200 to a Cradlepoint router that has a port defined with multiple vlans and IP ranges.  I'm trying to find out how to change the port type on the SG200 to a trunk port that will go to my Cradlepoint.
I see a way to define a tagged/untagged port on the SG200, but not a trunk port.  I'm missing something I'm sure, but where do I change the port type to trunk??
check page 182 of the attached user guide. You can set the Interface Vlan Mode to trunk...
You can also use the 'switch' smartport macro, which makes the port to which the macro is applied a trunk port...
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf20x_sg20x/administration_guide/Cisco_200Sx_v1_4_AG.pdf
