Set port speed to 100 on an old GB switch...
jmalge
Hi all,
We have an old 3508XL switch.  We are trying to connect a new 2960 to it but we purchased the incorrect SFP insert and that speed can only do 100mb.  We are getting link flaps and we suspect that it's a speed issue between the two. However, I cannot find how to set the speed on the old OS of the 3508 switch.
Below is a show version of the 3508 switch.
LR0007>show ver
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC17, RELE        ASE SOFTWARE (fc1)
Copyright (c) 1986-2007 by cisco Systems, Inc.
Compiled Tue 13-Feb-07 15:04 by antonino
Image text-base: 0x00003000, data-base: 0x00352924
ROM: Bootstrap program is C3500XL boot loader
LR0007 uptime is 43 weeks, 6 days, 23 hours, 19 minutes
System restarted at 09:36:48 EST Thu Feb 16 2012
System image file is "flash:c3500xl-c3h2s-mz.120-5.WC17.bin"
cisco WS-C3508G-XL (PowerPC403) processor (revision 0x01) with 8192K/1        024K bytes of memory.
Processor board ID CSG0735P0WC, with hardware revision 0x01
Last reset from power-on
Processor is running Enterprise Edition Software
Cluster command switch capable
Cluster member switch capable
8 Gigabit Ethernet/IEEE 802.3 interface(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:0D:65:21:07:C0
Motherboard assembly number: 73-3985-10
Power supply part number: 34-1000-01
Motherboard serial number: CAT07350870
Power supply serial number: APQ072800B4
Model revision number: P0
Motherboard revision number: A0
Model number: WS-C3508G-XL-EN
System serial number: CSG0735P0WC
Configuration register is 0xF
And here are the commans in conf t
LR0007(config)# int gi0/4
LR0007(config-if)#?
Interface configuration commands:
  arp                     Set arp type (arpa, probe, snap) or timeout
  bandwidth               Set bandwidth informational parameter
  carrier-delay           Specify delay for interface transitions
  cdp                     CDP interface subcommands
  custom-queue-list       Assign a custom queue list to an interface
  default                 Set a command to its defaults
  delay                   Specify interface throughput delay
  description             Interface specific description
  duplex                  Configure duplex operation.
  exit                    Exit from interface configuration mode
  fair-queue              Enable Fair Queuing on an Interface
  flowcontrol             Configure flow control operation.
  help                    Description of the interactive help system
  hold-queue              Set hold queue depth
  ip                      IP interface commands
  keepalive               Enable keepalive
  load-interval           Specify interval for load calculation for an interface
  logging                 Configure logging for interface
  loopback                Configure internal loopback on an interface
  mac-address             Manually set interface MAC address
  max-reserved-bandwidth  Maximum Reservable Bandwidth on an Interface
  mtu                     Set the interface Maximum Transmission Unit (MTU)
  mvr                     MVR per port configuration
  negotiation             Select Autonegotiation mode
  no                      Negate a command or set its defaults
  port                    Perform switch port configuration
  priority-group          Assign a priority group to an interface
  random-detect           Enable Weighted Random Early Detection (WRED) on an Interface
  rmon                    Configure Remote Monitoring on an interface
  service-policy          Configure QoS Service Policy
  shutdown                Shutdown the selected interface
  snmp                    Modify SNMP interface parameters
  spanning-tree           Spanning Tree Subsystem
  switchport              Set switching mode characteristics
  timeout                 Define timeout values for this interface
  transmit-interface      Assign a transmit interface to a receive-only interface
  tx-queue-limit          Configure card level transmit queue limit
  udld                    Configure UDLD enabled or disabled and ignore global UDLD setting
Thanks for all of your help.  this forum is great for stuff like this.
Jason Alge
mahmoodmkl
Level 7
Level 7
U will not be able to set the speed on this port as it is fixed.
