Setting maximum speed on ethernet interface?
OmahaGTP1
Community Member
I need to set a maximum line speed on an ethernet interface on a 2811 and 1812 series router.
Setting a line speed for a WAN connection, there is nothing to it.
Is there anyway to set a maximum speed on an ethernet interface without using traffic shaping QoS policies?
Thanks you for your time!
jgross
Level 4
Level 4
i,
I don't think that there is such a command on a router. On a switch you can use the
rr-queue bandwidth limit [percent]
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_40_se/command/reference/cli3.html#wp1947391
Bye
Jo
Joseph W. Doherty
For multiple speed Ethernet interfaces you can hard code a slower rate (i.e. 10 Mbps vs. 100 Mbps). Otherwise you'll need to shape or police.
