Setting passwords
VeteranMidfielder
Community Member
I have set a vty password and enable password for Cisco 2811 but after that when I take a tellnet connection the router asks Ciscon default username and password. ???
How can I disable these? I mean, when I connect with telnet, I don't want to log in with username and password.
I want that the router straight asks telnet password. So how to remove username and password?
Thanks for help. Sorry, this out of topic subject and bad English.
5 Replies 5
Collin Clark
Can you post the configuration of your VTYs?
show run | section vty
if that does not work, try-
show run | begin vty
Ganesh Hariharan
If router is asking for Username and password at the time of login then some local user database configuration would have been done or aaa authentication would have been configured.If you want to disable the usernam prompt just remove the local username and password database which is configured in the switch and in line vty 0 15 just configure password "password name" .
Hope that help
If helpful do rate the post
Ganesh.H
2 ways to do this.  if you have not done a lot of configurations, you can erase the startup config and reload or you can do a -->no username from the CLI.
stevec90
Level 2
Level 2
You need to have a VTY password in order to enable a telnet connection. You do not need a username. What I do is set a very long timeout on the VTY lines, so I only log in once at the beginning of the day.
Matthew Warrick
Level 3
Level 3
no aaa new-model
line vty 0 15
login
password XXXXXX
no exec-timeout
transport input telnet
This is not secure at all though.
