Setting up 881 Router
TehRobotNZ
I have a Cisco 881 router and would like some help setting it up to work with the situation described below.
The server needs to be accessible from both networks but needs to receive Internet from the right hand side.
Current setup is:
Left side has extensive WAN setup connect to the Internet with ip ranges 10.7.201.x - 10.7.216.x (Business)
Right hand side is a small office with ip range 10.1.1.x (Office)
The server will need to get its Internet from the connection at 10.1.1.1.  There is a physical connection from the router to the two networks
Port 1 - Business
Port 2 - Server
Port 3 - Office
Step by step help would be ideal as this is the first time I have needed to setup a cisco router like this (usually its just vlan tagging etc.) and I am self taught.
http://oi59.tinypic.com/10mpvs0.jpg
0 Replies 0
