Setting up a VPN connection
ashleyreed4218
Hello All:
I have to set up a vpn link between my remote Cisco switches and me. I believe we have the VPN server set up already. I am not sure what to do on my end to get comms going. (Haven't done this before). I.e, is there a config line that I need to add to my switches to enable remote access?
Thank you in advance,
Ashley
Richard Burts
Ashley
We need additional information to be able to give you good advice. VPN is supported on only a few switches and is more likely to be supported on routers. So as a starting point can you tell us what model of switch you are talking about? Also can you tell us a bit about the path from the remote switches to the main network?
Rick
Rick
