setting up dynamic vlan's
Rick Morris
Level 6
Level 6
We have a solution we are working on that requires dynamic vlan assignement.
We are setting up wireless guest access.
What are going to do is create an SSID for guest users, when the user authenticates to our ACS they will be given the VLAN info and access to the appropriate resources.
My question is how to set up the dynamic vlan's stuff?
We are using 4500's in our campus envorinment, but I would assume the config would be much the same on a 6509 or 3560 too?
Rick
garytayl
Level 3
Level 3
Rick,
This is what I used to configure something very similar to what you are trying to do:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a008076317c.shtml
In regards to your question of the different platforms, as longs as we are taking about IOS then configuration is very similar.
Hope it helps,
Gary
