Setting up notification for ACL denies
Cryen
I want to set up Notifications when an unknown Device Plugs into a Catalyst 3750 that is not in the ACL.
I just seem to can't figure out how to do it.
9 Replies 9
deny any any log <<- this what you need, add it to end of ACL
I tried this, but it says that the command is not known
balaji.bandi
what kind of ACL you have, IP ACL contains IP address, when the device plugged in the IP ACL may not have effect, if this is MAC ACL - or if the port have security configure, you will see log syslog message(if the logging is configured)
based on the syslog message - you can EEM Script to notify you email, also you like to action to shutdown the port can also be possible.
is this make sense ?
BB
it is an extended MAC ACL that i created with a Name.
I configured a bunch of permitted devices and at the end a "deny any any"
I can't the "log" at the end. Can you explain how to configure Port Security so it is logged and how to configure the EEM Script?
Thats the Limitation of MAC ACL, other option you can setup trap for MAC address and send to syslog and make out of the box report.
snmp-server enable traps MAC-Notification
snmp-server host x.x.x.x
interface gigx/x
snmp trap mac-notification added
snmp trap mac-notification removed
BB
Cryen
Config is something like this:
conf t
mac access-list extendend acl
permit host xxxx.xxxx.xxxx any
deny any any
All Interfaces have this ACL configured
Sorry the MAC ACL not support any LOG because
let explain
the MAC ACL is HW ACL i.e. done in TCAM not in CPU, the LOG message is generate from CPU and since the MAC ACL not run in CPU it not support LOG.
sad to hear that, but if that is the case then i guess it is not possible.
msrsu
I am also dealing with this problem.
