Setting up port duplex
jahanzeb.feroze
I am trying to set up the speed duplex as "full", but the port not allowing me this operation, showing the error of unrecognized command, however beside this port, all the other ports on same switch are accepting the command.
Note: Cross cable is connected to this port.
Please suggest
24 Replies 24
4500 side set duplex auto?  If not set both sides auto.
Want to set it to 1000 due to certain requirements, auto will not work for me.
Please help
Can you copy and paste the output from
show run int g0/24
for both sides of the link that is experiencing half duplex?
GigabitEthernet0/24 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 0021.565b.9798 (bia 0021.565b.9798)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive not set
  Half-duplex, 100Mb/s, link type is auto, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:14, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 2000 bits/sec, 5 packets/sec
  5 minute output rate 1000 bits/sec, 3 packets/sec
     8532345 packets input, 685285873 bytes, 0 no buffer
     Received 6122657 broadcasts (0 multicasts)
     244 input errors, 113 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 5923756 multicast, 0 pause input
     1215095 packets output, 147874876 bytes, 0 underruns
     0 output errors, 65 collisions, 1 interface resets
     0 babbles, 23 late collision, 0 deferred
You pasted the show interface info, but I was asking for the show run interface info.
This is only one side of the link as well.  Both sides need to match.
Since duplex command is not allowed on a gigabit port on the 2960 switches, I would configure
int g0/24
speed 1000
and do this on both sides of the link.  If there is not a cabling issue, this should clear up the half duplex and change it to full duplex.
First configure the speed as 1000, as the duplex is only considered after detecting speed of the interface.
Then hard code the duplex as Full, then check the gi0/24 interface output you should be seeing 1000/Full.
Check for CRC or speed issues, if you are getting any error counters incrementing then reset the interface using clear interface gig0/24 command.
According to the 2960 configuration guide,
Duplex command is not available on gig ports.
"You cannot configure half-duplex mode for interfaces operating at 1000 Mb/s.
You get a unrecognized command when you attempt to configure duplex on a 2960 gig port.
But on rest of the ports, i am able to set duplex at full, without any issue,
here is the sh run of gig0/24 for you,
interface GigabitEthernet0/24
 switchport trunk allowed vlan 99
 switchport mode trunk
end
port info for the other end,(4500)
interface GigabitEthernet0/9
 speed 100
 duplex full
end
On other ports of 2960 (just to show u that i am able to config speed as duplex on other 2960 ports)
interface GigabitEthernet0/20
 switchport mode access
 shutdown
 speed 100
 duplex full
Please suggrst
Change the 4500 end to
speed auto
duplex auto
and that normally clears up the half duplex issue.
If this helps, please rate.
Thanks cehil, will try and get back to u .
