Setting up Routing and Vlans
Patrick Evans
Hi Guys,
I am trying to configure my lab with Vlans and access to the internet VIA my Virgin Media router.  I have had this working but while messing around i have broken it.  Can anyone give me a hint as to how?  Below is my router configuration.  My laptop is connected to a switch and is pulling 192.168.10.1/24 via DHCP  Thanks
Current configuration : 1681 bytes
version 12.4
hostname CBTRouter
boot-start-marker
boot-end-marker
enable secret 5 $1$XtrM$gDxcY6FRQ3LQWGfY./E4K.
no aaa new-model
no network-clock-participate slot 1
no network-clock-participate wic 0
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.0.50
ip dhcp excluded-address 192.168.10.50
ip dhcp pool dpool1
   import all
   network 192.168.10.0 255.255.255.0
   default-router 192.168.10.50
no ip domain lookup
ip domain name CBTRouter.com
ip name-server 8.8.8.8
ip name-server 8.8.4.4
interface FastEthernet0/0
no ip address
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/0.10
description VLAN10 LEFT
encapsulation dot1Q 10
ip address 192.168.10.50 255.255.255.0
ip nat inside
interface FastEthernet0/0.20
description VLAN21 RIGHT
encapsulation dot1Q 20
ip address 192.168.20.50 255.255.255.0
interface Serial0/0
no ip address
shutdown
interface FastEthernet0/1
ip address dhcp
ip nat outside
duplex auto
speed auto
ip route 192.168.10.0 255.255.255.0 FastEthernet0/1
no ip http server
no ip http secure-server
ip nat pool no-overload 192.168.0.100 192.168.0.150 prefix-length 24
ip nat inside source list 7 pool no-overload
access-list 7 permit 192.168.10.0 0.0.0.255
control-plane
banner motd ^CC
My router. Keep out.^C
line con 0
exec-timeout 0 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
password cisco
login
end
7 Replies 7
daniel.dib
Level 7
Level 7
Why are you doing NAT on this device? Just to test?
Did your router receive an IP via DHCP and also a default route? Check that fa0/1 has an IP and that you have a default route with show ip route.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
Please rate helpful posts.
Yes i am just testing really.
FastEthernet0/1    192.168.0.7    YES DHCP   up   up
Gateway of last resort is 192.168.0.1 to network 0.0.0.0
C    192.168.10.0/24 is directly connected, FastEthernet0/0.10
C    192.168.20.0/24 is directly connected, FastEthernet0/0.20
C    192.168.0.0/24 is directly connected, FastEthernet0/1
S*   0.0.0.0/0 [254/0] via 192.168.0.1
I dont understand the static route in there. Where did that come from?  The 192.168.0.1 is my virgin media router but the only config i entered is:
Patrick
The "static" default route came from DHCP.
Is the Virgin router setup to do NAT for the 192.168.10.0/24 network? Does it have a route back for this network? What was the last change that you did?
Why did you put this route in:
That network is local to the router.
Daniel Dib
CCIE #37149
Daniel Dib
CCIE #37149
CCDE #20160011
The last changes i made was creating the Vlans etc.  From the router I can ping out to the internet and i can also ping in to my laptop.
The Virgin is just a standard VM superhub made by Netgear i think.   I have made no changes to that at all.
ip route 192.168.10.0 255.255.255.0 FastEthernet0/1- I am confused with this.  I though that this command should mean that anything from the .10 network should leave on F0/1.  Should i remove this?
Thanks for your assistance.
Patrick
No, it means that anything destined for 192.168.10.0/24 is located out fa0/1.
It is not necessary because this 192.168.10.0/24 is already directly connected as an IP address in this network was configured on f0/0.10. As the AD of connected interface iz zero and AD of static route is 1, this static route will never be installed in the routing table.
Regards.
Alain
LUKASZ KITA
I see there is a 1 problem with vlan 21 and encapsulation is dot1q 20. A little mistake.
Sent from Cisco Technical Support Android App
Well spotted.  I have checked this over and it was just the description that was incorrect so i have changed that.
Patrick
