Setting uplink port on Catalyst 2900 series Switch
Chris_M_Miller
Greetings, I'm working on my CCNA and I want to copy down the IOS to my Linux box via TFTP before making any major configuration changes (basically back it up).
I've noticed I don't have an uplink port on the Switch and not really sure how to go about this.
Also can I use CAT5 or will I have to use Cross-Over?
thanks
Leo Laohoo
As long as the speed and duplex are set to auto then MDI/MDI-X is enabled.
Connect your host to the switch, give the switch an IP address and enable TFTP and you should be able to copy the IOS from the switch to the client.
[quote]
[/quote]
I'm not sure how to confirm if MDI/MDI-X is enabled or not on the Switch.
Forgot to include this other detail.  All of the devices (Linux pc and Cisco Switch) are connected to a Linksys SOHO Router/Switch.  Will this make a difference?  I wouldn't think so as long both devices can ping each other.
thanks
In the interface configuration, enter the command "mdix auto".
