Setup for connecting Router AUX port to switch console port.
Hello everyone, I was looking for a way to connect an AUX port from a 1700 router to a 6500 switch module console port, to see the output of the Switch's on the 1700 router, in case there is a network downtime, I could see what's going on in the switch, what cable should I use ? Also, is  there is any kind of documentation for this type of config what have I seen is very few info.
Thanks in advance, kind regards.
John Blakley
It may be easier to set up a crossover cable to a workstation running Wireshark. I've taken a console cable and connected it to a workstation and then connect the rj-45 connection into the wall jack. On the other end, I took a standard patch cable and connected it into the console port on a router. I was able to get a console connection from the workstation, so I think you would need to cut off the db9 connector and simply wire it as a straight through connection and crimp it. I would test that first by connecting it to a test router to see if you get anything back though...
Aside from that, I highly doubt that you'll be able to see anything on your router though if your switch were to flake out. These are console messages and not packet captures...
HTH, John *** Please rate all useful posts ***
Conect port AUX CISCO to port CONSOLE :
Config device port aux
user cisco password cisco
int loopback 100
ip address 1.1.1.1 255.255.255.255
line aux 0
login local
modem autoconfigure discovery
no exec
transport input all
telnet transparent
speed 9600
use ROLLOVER cable
RJ45     RJ45
1                8
2                7
3                6
4                5
5                4
6                3
7                2
8                1
use command "show line"
show line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 CTY - - - - - 6 0 0/0 -
5 AUX 9600/9600 - - - - - 10 28 0/0 -
* 6 VTY - - - - - 33 0 0/0 -
7 VTY - - - - - 13 0 0/0 -
8 VTY - - - - - 20 0 0/0 -
9 VTY - - - - - 10 0 0/0 -
10 VTY - - - - - 4 0 0/0 -
Line(s) not in async mode -or- with no hardware support:
1-4
port AUX -> LINE 5
telnet "IP loopback" "port"  example port AUX 5 "port=2000+5"
Trying 1.1.1.1, 2005 ... Open
User Access Verification
Username: cisco
Password:*****
telnet 1.1.1.1 2005
