06-26-2012
09:31 AM
- last edited on
03-25-2019
04:20 PM
by
ciscomoderator
I am trying to connect a SF200-48 switch via Mini-GBIC MGBLX1 fibre module to a Cisco 3750 switch with a GLC-SX-MM fibre module installed both running a 1000 Mbps. When connected together they do not enable. Are there compatibility restrictions or is it that the Mini-GBIC modules cannot be used to uplink to a LAN?
Solved! Go to Solution.
06-26-2012 05:55 PM
John,
At the SF200 end you have a long haul single mode fibre mod
At the 3750 you have a short haul multi mode fibre module
These are incompatable
You will need to change one end and use the corresponding type of cable
A Mini-GBIC-MGBSX1 should work with a max of about 500m over multimode fibre
Alex.
Please rate useful posts.
06-26-2012 05:55 PM
John,
Alex.
06-27-2012 12:48 AM
Thank you for the reply Alex, I will look at swapping the module and I'll try again.
