Interface specified on "distribute-list in" for EIGRP
Alex Mac
Hi folks,
it looks that if I specify the incoming interface for the EIGRP updates then the filter does not longer work, see router 7 under section "router eigrp"
If I don't specify the interface everything works perfectly.
Topology:
R8---R7---R3
Relevant configurations
--------------- R7 ---------------
version 12.4
hostname R7
ip cef
interface FastEthernet0/0
ip address 192.168.1.7 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.77.254 255.255.255.0
duplex auto
speed auto
router eigrp 23
network 192.168.1.0
distribute-list 1 in FastEthernet0/0
auto-summary
router ospf 2
log-adjacency-changes
redistribute eigrp 23 subnets
network 192.168.77.0 0.0.0.255 area 0
access-list 1 deny   192.168.88.0
access-list 1 deny   10.10.2.64 0.0.0.63
access-list 1 deny   10.10.3.128 0.0.0.63
access-list 1 permit any
access-list 2 deny   172.16.77.0 0.0.0.255
access-list 2 permit any
--------------- R8 ---------------
version 12.4
hostname R8
ip cef
ip address 192.168.1.8 255.255.255.0
duplex auto
speed auto
ip address 192.168.88.254 255.255.255.0
duplex auto
speed auto
interface Ethernet1/0
ip address 10.10.1.254 255.255.255.224
half-duplex
interface Ethernet1/1
ip address 10.10.2.126 255.255.255.192
half-duplex
interface Ethernet1/2
ip address 10.10.3.190 255.255.255.240
half-duplex
interface Ethernet1/3
ip address 10.10.3.158 255.255.255.224
half-duplex
router eigrp 23
network 10.10.0.0 0.0.255.255
network 192.168.1.0
network 192.168.88.0
no auto-summary
--------------- R3 ---------------
version 12.4
hostname R3
ip cef
ip address 172.16.77.3 255.255.255.0
duplex auto
speed auto
ip address 192.168.77.3 255.255.255.0
duplex auto
speed auto
router ospf 2
network 172.16.77.3 0.0.0.0 area 0
network 192.168.77.3 0.0.0.0 area 0
R7#sh ip ei top
IP-EIGRP Topology Table for AS(23)/ID(192.168.77.254)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
       r - reply Status, s - sia Status
P 192.168.88.0/24, 1 successors, FD is 30720
        via 192.168.1.8 (30720/28160), FastEthernet0/0
P 10.10.2.64/26, 1 successors, FD is 284160
        via 192.168.1.8 (284160/281600), FastEthernet0/0
P 192.168.1.0/24, 1 successors, FD is 28160
        via Connected, FastEthernet0/0
P 10.10.3.128/27, 1 successors, FD is 284160
P 10.10.3.176/28, 1 successors, FD is 284160
P 10.10.1.224/27, 1 successors, FD is 284160
R7#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
D    192.168.88.0/24 [90/30720] via 192.168.1.8, 00:04:25, FastEthernet0/0
C    192.168.77.0/24 is directly connected, FastEthernet0/1
     172.16.0.0/24 is subnetted, 1 subnets
O       172.16.77.0 [110/2] via 192.168.77.3, 00:04:46, FastEthernet0/1
     10.0.0.0/8 is variably subnetted, 4 subnets, 3 masks
D       10.10.2.64/26 [90/284160] via 192.168.1.8, 00:04:25, FastEthernet0/0
D       10.10.3.128/27 [90/284160] via 192.168.1.8, 00:04:25, FastEthernet0/0
D       10.10.3.176/28 [90/284160] via 192.168.1.8, 00:04:26, FastEthernet0/0
D       10.10.1.224/27 [90/284160] via 192.168.1.8, 00:04:26, FastEthernet0/0
C    192.168.1.0/24 is directly connected, FastEthernet0/0
R7#
So the ACL 1 should filter some networks but it does not. If I remove the interface option then everything works as expected.
My understanding is that I can select the interface on which filter the updates but it does not work in my scenario.
Am I wrong with my understanding or/and with my configs?
I refer to this document:
http://www.cisco.com/en/US/tech/tk365/technologies_tech_note09186a0080208748.shtml
Thx in advance for any help,
Alex
I'm running:
Cisco IOS Software, 3700 Software (C3745-ADVENTERPRISEK9-M), Version 12.4(15)T14,
And it works perfectly...
HTH, John *** Please rate all useful posts ***
5 Replies 5
Alex Mac
I found a similar case here:
http://ieoc.com/forums/p/6821/24109.aspx
Your understanding is correct and it works for me. What IOS version are you running? Are you doing this on real equipment or GNS?
Hi J,
thanks for your confirmation.
The version I'm playing with is 12.4(15)T7. I see this on GNS.
Meanwhile I've found this post
http://ieoc.com/forums/p/15537/131577.aspx
Likely it's a bug, wondering which one...
I'll see if with 12.4(24)T2 the weirdness disappears...
Do you perhaps have more info on that?
Alex
I'm running:
Hi J,
indeed with 12.4.17 I don't see the issue either. It must be a bug.
Thanks for your contribution to solve the issue
Alex
