sf300-48pp And port aggregation
We have in a branch office two 4Mo SDSL Line (MPLS).
We put these lines in a port aggregation with load balancing in order to provide a better service.
The two lines are up.
We experienced these troubles :
  • One PC looses one ping on three. Web application are always unconnecting, reconnecting.
  • When we bring a new PC, it become impossible to connect it to the network. An ipconfig shows an unplugged cable
When we delete the aggregation, everything come back fine.
Is it OK to make an aggregation with two SDSL ?
How can I toubleshoot the problem ? MY provider says the lines are fine.
Mark Malone
You should be able to do it but you may need the ISP involved you could try use MLPPP as 1 type of feature not sure if that would work fully with mpls though on provider side  , if you cant use the ISP you can load balance across the 2 links using CEF , use equal default routes for both links and setup ip cef load-sharing
Have you talked to your provider about getting bonded sdsl , you may need a specific wic in the router to achieve this on your side though but i think its possible in some cases
Just an option to try anyway
http://www.cisco.com/c/en/us/td/docs/ios/ipswitch/configuration/guide/12_4/isw_12_4_book/cef_load_balancng.html
