SF500 and
bbitar001
I need simple techincal support as per following Scenario
Our existing site contains Cisco Switch C3750G-12S-S, whereas our new site is composed of 2 Nodes.
Node 1 has 3 Stackable switches and Node 2 has 4 Stackable Switches.
Both Nodes shall be connected to the main existing Site via fiber cable.
We need a solution that allows us to connect the C3750G-12S-S ( Existing site)  to the SF500-24P ( nodes)  via fiber optic tranceivers  that allows full Fiber SFP compatibility.
I got to this solution but I need experince confirmation:
MGBSX1 Gigabit Ethernet SX Mini-GBIC SFP Transceiver from SF500 side and GLC-SX-MMD from C3750G-12S-S side using multimode fiber optic cable 9 less than 500 m )
would you please confirm if this will work
Mark Malone
Hi I would move this to the Lan switching or small business section , you will get more replies than the Café area
It should work fine though both transceivers support MM and both are the correct transceivers for their devices and supported , lc-lc om3 cable should work fine if you have that , both have identical hardware capabilities too so they should sync easily
Heres the 1gb matrix for catalyst
https://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html#_Toc493061007
sf400 shows your MX sfp too as supported
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/Sx500/administration_guide/500_Series_Admin_Guide.pdf
