%SFF8472-5-THRESHOLD_VIOLATION
takhan
hello guys!
I got logs  from  4507R-E   image : at4500es8-universalk9.SPA.03.08.04.E.152-4.E4.bin
I use 10 gigabit gibic  all of upling to L2 Swtichs..
there are no problem to service..
logs says
eb 25 11:10:30.704: %SFF8472-5-THRESHOLD_VIOLATION: Te1/2: Tx power high warning; Operating value: -1.1 dBm, Threshold value: -1.3 dBm.
Feb 25 11:10:34.721: %SFF8472-5-THRESHOLD_VIOLATION: Te1/5: Tx power high warning; Operating value: -0.9 dBm, Threshold value: -1.3 dBm.
Feb 25 11:10:40.675: %SFF8472-5-THRESHOLD_VIOLATION: Te1/8: Rx power high warning; Operating value: -0.2 dBm, Threshold value: -1.0 dBm.
Feb 25 11:10:42.644: %SFF8472-5-THRESHOLD_VIOLATION: Te1/9: Tx power high warning; Operating value: -1.1 dBm, Threshold value: -1.3 dBm.
Feb 25 11:10:44.645: %SFF8472-5-THRESHOLD_VIOLATION: Te1/11: Tx power high warning; Operating value: -1.0 dBm, Threshold value: -1.3 dBm.
Feb 25 11:11:07.573: %SFF8472-5-THRESHOLD_VIOLATION: Gi6/2: Tx power high warning; Operating value: -2.9 dBm, Threshold value: -3.0 dBm.
Feb 25 11:11:15.196: %SFF8472-5-THRESHOLD_VIOLATION: Te2/3: Tx power high warning; Operating value: -0.9 dBm, Threshold value: -1.3 dBm.
Feb 25 11:11:21.575: %SFF8472-5-THRESHOLD_VIOLATION: Te2/10: Tx power high warning; Operating value: -1.2 dBm, Threshold value: -1.3 dBm.
Feb 25 11:11:28.022: %SFF8472-5-THRESHOLD_VIOLATION: Te2/8: Tx power high warning; Operating value: -1.1 dBm, Threshold value: -1.3 dBm.
Feb 25 11:11:28.868: %SFF8472-5-THRESHOLD_VIOLATION: Te2/6: Tx power high warning; Operating value: -0.7 dBm, Threshold value: -1.3 dBm.
Feb 25 11:11:30.753: %SFF8472-5-THRESHOLD_VIOLATION: Te2/9: Tx power high warning; Operating value: -1.0 dBm, Threshold value: -1.3 dBm.
Feb 25 11:11:41.424: %SFF8472-5-THRESHOLD_VIOLATION: Te2/5: Rx power low warning; Operating value: -12.5 dBm, Threshold value: -9.9 dBm.
every 10 minute ..
and any other 10 gigabit gibic are ok ..
can you help me,.,? how to solve ?
the message could indicate a problem with the transceiver and/or the fiber cable. Try to swap the transmit/receive ends of the cable, and/or reseat the transceiver, and/or replace either both the transceiver and the cable...
Leo Laohoo
Try a different firmware. 3.8.4 is pretty old.
