SFF8472 load CPU
sand-max83
Visitor
Hi Guys!
I faced with  problem SFP.
SFF8472 is loaded high CPU. For example , I have 6 SFP now and ~28%  CPU utilization.
I noticed each SFP loaded CPU + ~4%. When plugged 24 SFP switch cannot loaded at all
cisco-3750X#show processes cpu sorted
CPU utilization for five seconds: 43%/0%; one minute: 44%; five minutes: 44%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
63 126295070 1998399 63199 27.83% 27.88% 27.93% 0 SFF8472
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : A0:55:4F:B2:A8:80
Motherboard assembly number : 73-12554-05
Motherboard serial number : FDO1844S23C
Model revision number : A0
Motherboard revision number : D0
Model number : WS-C3750X-24S-S
Daughterboard assembly number : 800-32786-01
Daughterboard serial number : FDO15390PLP
System serial number : FDO1848H0QR
Top Assembly Part Number : 800-33746-06
Top Assembly Revision Number : F0
Version ID : V05
CLEI Code Number : CMMP200DRA
Hardware Board Revision Number : 0x05
Switch Ports Model SW Version SW Image
* 1 30 WS-C3750X-24S 15.0(2)SE5 C3750E-UNIVERSALK9-M
I googled and cisco recommended using other SFP. But maybe someone known other way of workaround
0 Replies 0
