SFP-10G-SR connect to 1000BaseSX SFP? how?
Phi Bui Chau
Dear all!
My company bought new 4500x replacement for 3750 switches
I want to switch pairs 3750 to become access switch
on 3750s have 2 1000 BASESX SFP ports, and I want it connect to new 4500x via trunking protocol (4500x use SFP-10G-SR module)
I used LC-LC cable, but it didnt work. link and interface are all down
What must i do now?
Marvin Rhoads
You cannot interconnect these two transceiver types - they are incompatible. One operates only at 1 Gbps and the other operates only at 10 Gbps.
You can use 1 Gbps transceivers in the 4500X. Compatible types are listed here. (You would need the GLC-SX-MM.)
