SFP and SFP+
gustavo.pena
I'd like to know if it is possible to use SFP for 1 Gbps in a WS-C2960X-24TD-L that supports SFP+ modules, and if I want to upgrade later to 10 Gbps simply I change the SFP?
Thanks in advanced
andre.ortega
Yes, you can do that.
Here is the list of supported SFPs.
http://www.cisco.com/c/en/us/td/docs/interfaces_modules/transceiver_modules/compatibility/matrix/GE_Tx_Matrix.html
Ganesh Hariharan
Agree with Andre,
10Gbps SFP is supported with WS-C2960X-24TD-L, Check out the compatibility matrix for your reference.
Compatibility Matrix for 10Gbps SFP
Hope it Helps..
-GI
