04-08-2015 08:46 AM - edited 03-07-2019 11:27 PM
I have cisco switch WS-C2960S-24TS-S with IOS 12.2(55)SE8 C2960S-UNIVERSALK9-M when I connect the SFP Cisco GLC-SX-MM to the interface the switch does not know it .
Switch#sh interfaces gig0/25 status
Port Name Status Vlan Duplex Speed Type
Gi0/25 err-disabled 1 auto auto unknown
04-08-2015 08:52 AM
Please post the complete output to the command "sh interface status err".
04-08-2015 09:17 AM
Thanks leo
I will try this command and I will confirm you .
04-12-2015 06:11 AM
This is the output of the commend
Switch#show int status err-disabled
Port Name Status Reason Err-disabled Vlans
Gi0/25 err-disabled gbic-invalid
04-12-2015 08:54 AM
What happens, if you do a shut and no shut on these interface?
Madhu
04-12-2015 12:00 PM
Switch(config)#int gigabitEthernet 0/25
Switch(config-if)#sho
Switch(config-if)#shu
Switch(config-if)#shutdown
Switch(config-if)#do sh
*Mar 1 00:08:10.481: %LINK-5-CHANGED: Interface GigabitEthernet0/25, changed state to administratively down ip int br
Vlan1 unassigned YES unset up up
FastEthernet0 unassigned YES unset down down
GigabitEthernet0/1 unassigned YES unset down down
GigabitEthernet0/2 unassigned YES unset down down
GigabitEthernet0/3 unassigned YES unset down down
GigabitEthernet0/4 unassigned YES unset down down
GigabitEthernet0/5 unassigned YES unset down down
GigabitEthernet0/6 unassigned YES unset down down
GigabitEthernet0/7 unassigned YES unset down down
GigabitEthernet0/8 unassigned YES unset down down
GigabitEthernet0/9 unassigned YES unset down down
GigabitEthernet0/10 unassigned YES unset down down
GigabitEthernet0/11 unassigned YES unset down down
GigabitEthernet0/12 unassigned YES unset down down
GigabitEthernet0/13 unassigned YES unset down down
GigabitEthernet0/14 unassigned YES unset down down
GigabitEthernet0/15 unassigned YES unset down down
GigabitEthernet0/16 unassigned YES unset down down
GigabitEthernet0/17 unassigned YES unset down down
GigabitEthernet0/18 unassigned YES unset down down
GigabitEthernet0/19 unassigned YES unset down down
GigabitEthernet0/20 unassigned YES unset down down
GigabitEthernet0/21 unassigned YES unset down down
GigabitEthernet0/22 unassigned YES unset down down
GigabitEthernet0/23 unassigned YES unset down down
GigabitEthernet0/24 unassigned YES unset up up
GigabitEthernet0/25 unassigned YES unset administratively down down
GigabitEthernet0/26 unassigned YES unset down down
Switch(config-if)#no shut
Switch(config-if)#
*Mar 1 00:08:30.326: %LINK-3-UPDOWN: Interface GigabitEthernet0/25, changed state to down
Switch(config-if)#
Switch#show ip int brief
Vlan1 unassigned YES unset up down
GigabitEthernet0/24 unassigned YES unset down down
GigabitEthernet0/25 unassigned YES unset down down
Switch#
Mar 1 00:07:55.508: %GBIC_SECURITY_CRYPT-4-VN_DATA_CRC_ERROR: GBIC in port Gi0/25 has bad crc
*Mar 1 00:07:55.508: %PM-4-ERR_DISABLE: gbic-invalid error detected on Gi0/25, putting Gi0/25 in err-disable state
*Mar 1 00:08:24.003: %GBIC_SECURITY_CRYPT-4-VN_DATA_CRC_ERROR: GBIC in port Gi0/25 has bad crc
*Mar 1 00:08:39.144: %GBIC_SECURITY_CRYPT-4-VN_DATA_CRC_ERROR: GBIC in port Gi0/25 has bad crc
Mar 1 00:24:18.611: %GBIC_SECURITY_CRYPT-4-VN_DATA_CRC_ERROR: GBIC in port Gi0/25 has bad crc
*Mar 1 00:24:18.611: %PHY-4-UNSUPPORTED_TRANSCEIVER: Unsupported transceiver found in Gi0/25
04-08-2015 08:57 AM
Hi khalid,
Is it being recognized in another port?
It could be a bad SFP also. Also why is the port err-disabled? Did you check on that?
Madhu.
04-08-2015 09:15 AM
Thanks Madhu
I tried it in another port,with same Issue .
04-08-2015 09:25 AM
Try check with another spare GLC-SX-MM ?
If that works get this one replaced.
Madhu
04-12-2015 06:06 AM
I replaced with another cisco GLC-SX-MM with same issue .
