SFP Compatibility question
andrey.nikolov
Hello, we are your partner and have the following request.
We use WS-C2960X-48TS-LL and WS-C3850-48T-E Catalyst Switch. My question is whether these models SFP are compatible with these models switches:
1. APS31123CDL20 - 1.25G 1310nm 20KM
2. ATOP AP-ST1 1000BASE-T SFP
Reza Sharifi
These are not Cisco SFP part numbers.  So, it may or may not work. You just have to try it to find out. Not every 3rd party optics work with Cisco equipment.
if you do not recognize can it use this command:
3850(config)# no errdisable detect cause gbic-invalid
3850(config)# service unsupported-transceiver
3850s don't support
"service unsupported-tran" command anymore.
You can try the first command and test the SFP.
