SFP-GE-T models Incompatibility with ASR1001
hcuellar91
Hi all!
I've working with an ASR1001 and connecting different transceivers to it, I have some SFP-GE-T with Part Number: 30-1421-03 and they not working! I have the same model SFP with different part number too (30-1421-02) and it works perfectly.
Is there any compatibility problem with this part number: 30-1421-03 ?
The only difference I can see is:
router#sh hw-module subslot 0/0 transceiver 0 idprom
IDPROM for transceiver GigabitEthernet0/0/1:
  Description                               = SFP or SFP+ optics (type 3)
  Transceiver Type:                         = GE T (26)
  Product Identifier (PID)                  = N/A
  Vendor Revision                           = V03
  Serial Number (SN)                        = MTC1603002Q
  Vendor Name                               = CISCO-METHODE
  Vendor OUI (IEEE company ID)              = 00.00.00 (0)
  CLEI code                                 =
  Cisco part number                         =
  Device State                              = Enabled.
  Date code (yy/mm/dd)                      = 20/14/05
  Connector type                            = Unknown.
  Encoding                                  = 8B10B
                                              NRZ
  Nominal bitrate                           = GE (1300 Mbits/s)
  Minimum bit rate as % of nominal bit rate = not specified
  Maximum bit rate as % of nominal bit rate = not specified
router#sh hw-module subslot 0/0 transceiver 1 idprom
  Vendor Revision                           =
  Serial Number (SN)                        = MTC184708UA
  CLEI code                                 = IPUIAPARAB                                        <--------
  Cisco part number                         = 30-1421-02                                       <--------  30-1421-02 have this info and the other model not
  Date code (yy/mm/dd)                      = 14/11/24
  Encoding                                  = 8B10B
                                              NRZ
Please help, what can I do to make 30-1421-03 work??? I bought 10 and none works.
Thanks so much
Regards!
0 Replies 0
