Static route setup help
jbpollard
Community Member
Studying for my CCNA using gns3 getting a little lost on creating a static route to let traffic flow from the client pc. The client cant ping 192.168.20.1 but I am unable to ping 192.168.2.1 or access the internet from it.
ESW1 Config
Full Config esw1.txt
ip forward-protocol nd
ip route 192.168.2.0 255.255.255.0 192.168.20.1
ip http server
no ip http secure-server
ip http path flash:
ip nat inside source list 100 interface FastEthernet0/0 overload
access-list 100 permit ip any any
no cdp log mismatch duplex
ESW2 Config
Full Config esw2.txt
ip route 0.0.0.0 0.0.0.0 192.168.2.1
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0
ip route 192.168.10.0 255.255.255.0 192.168.20.3
Hello again,
esw3 has no routes configured so will only now how to forward packets on the same link (connected).
Try adding:
esw3:
ip default-gateway 192.168.2.1
ip route 192.168.10.0 255.255.255.0 192.168.2.72
ip route 192.168.20.0 255.255.255.0 192.168.2.72
Come to think of it, esw2 will also need a default route too:
You should really consider runing an IGP (OSPF or EIGRP) between your routers. Just redistributing the connected routes would automate this route configuration.
I'm not familiar with how GNS3 connects your virtual network with the 'cloud' object. Is the subnet 192.168.2.0/24 a real world subnet that your simulation is bridged to? Does the cloud object NAT?
cheers,
Seb.
cheers,
Seb.
5 Replies 5
Seb Rupik
Hi there,
It looks like you need the following on esw2:
ip routing
ip cef
cheers,
Seb.
That may have been part of the problem I added that into the config...
To troubleshoot further I removed DHCP from router ESW2 assigned the IP manually to fa0/0. I also added a 3rd router just to give it something to ping to rule out cloud issues.
ESW2  esw2.txt
S    192.168.10.0/24 [1/0] via 192.168.20.3
C    192.168.20.0/24 is directly connected, FastEthernet0/1
C    192.168.2.0/24 is directly connected, FastEthernet0/0
ESW1  esw1.txt
C    192.168.10.0/24 is directly connected, FastEthernet0/1
C    192.168.20.0/24 is directly connected, FastEthernet0/0
S    192.168.2.0/24 [1/0] via 192.168.20.1
I can ping 192.168.2.73 "esw3.txt" from ESW2. And I can ping 192.168.2.72 from the host pc.
When I do a wiresharck on the ESW3 connection it appears to see the packet but shows this.
Hello again,
Try adding:
esw3:
cheers,
Seb.
cheers,
Seb.
Yeah I definitely will if this was real environment I'm just studying. I had the 192.168.10.0 static route I was just missing the other one "ip route 192.168.20.0 255.255.255.0 192.168.2.72".
devils_advocate
Level 11
Level 11
I could be wrong but I believe NAT cannot work with any any in the source ACL.
Could you try and change it to:
access-list 100 permit ip 192.168.0.0 0.0.255.255
Apologies if I am incorrect but something in the back of my brain jumped forward when I saw any any in the NAT ACL.
