SFP-H10GB-CU5M cable to connect SUP7L-E to C3KX-NM-10G= on 3750X
lefernandez
Hi everyone
I would like to know if it is supported connecting the SUP7L-E 10GE ports to a C3KX-NM-10G, using a SFP-H10GB-CU5M (or shorter).
Thanks in advance
Luis Eloy
Ivan Shirshin
As I understand, you have 3750 with C3KX-NM-10G module in it that you want to connect to 4500 with sup7L-E. This NM module has four physical ports with two SFP+ and two regular SFP ports.
The following SFP+options work for both from sup7L-E and C3KX-NM-10G:
     SFP-H10GB-CU1M= 1-m 10G SFP+ Twinax cable assembly, passive
     SFP-H10GB-CU3M= 3-m 10G SFP+ Twinax cable assembly, passive
     SFP-H10GB-CU5M= 5-m 10G SFP+ Twinax cable assembly, passive
See the SFP compatibility list here:
http://www.cisco.com/en/US/docs/interfaces_modules/transceiver_modules/compatibility/matrix/OL_6974.pdf
Note that you need SFP+ version 2 and that there are minimum SW requirements as well.
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
Kind Regards,
Ivan
Ivan Shirshin
Kind Regards,
Ivan Shirshin
Kind Regards,
Ivan
thanks for the answer
I have accidentally rated your answer too low (not used to the iPad interface)
sorry for that
It's ok :-) welcome!
Kind Regards,
Ivan
