SFP+ in X2 port on sup2t?
mbesim
Is it possible to connect 3750X with C3KX-NM-10G to X2 10G port on sup2t in 6500E switch.
There is Cisco OneX Converter Module, but I could not find that it is supported on sup2t.
Any advice? Thanks.
Reza Sharifi
Yes, all you need is a fiber patch cord with one side SC (6500) and the other side LC (3750X).
no need for converter.
Thank you, Reza.
I guess there should be SFP+ module in 3750 SFP+ port. Is that right?
Is SFP-10G-SR OK?
There is no need to place any module in X2 port on sup2t.
So I could use the other port on sup2t for VSS (VSL). I only need fiber patch cord with SC on both sides. Is that correct?
Thanks again.
