SFP module comparison between network devices
After Connecting the Module in the Switch, switch is detecting the module but after connecting LC to LC fiber cable between any switch ,it is not detecting the link. suggest pls.
Yachay
Level 5
Level 5
Which SFP module and switch are you using?
Seb Rupik
Hi there,
Are the SFPs at either end compatible?
Have you tried crossing over the fibre at one end?
cheers,
Seb.
johnd2310
Level 11
Level 11
Hi, Have you tried crossing-over the fibres? Thanks John
**Please rate posts you find helpful**
