SFP Module compatibility
kartik.shah1
Are MGBLX1 SFP modules compatibile with SG350X-24 & SG350X-48?
In datasheet it is not showing, instead it is showing MGBLH1 (supported upto 40km).
I am attaching datasheet for reference.
Please guide.
Thanks.
pigallo
no it looks like it's not supported, but there's a switch compatibility list for the transceiver.
https://www.cisco.com/c/dam/en/us/td/docs/interfaces_modules/csbna/mgb/quick_start/guide/Optical_Module_QSG_en-US.pdf
i'm not sure if you already have the switches, the transceiver or both.   :)
Maybe this can help you.
