SFP power down .. 6500 switch
Hiii to u all
Im facing the fllowing problem in switch 6509..
SW_Admin#show module
Mod Ports Card Type Model Serial No.
0 24 CEF720 24 port 1000mb SFP WS-X6724-SFP SAL08290RYV
Mod MAC addresses Hw Fw Sw Status
0 0000.0000.0000 to 0000.0000.0000 2.1 12.2(14r)S5 12.2(18)SXD3 PwrDown
Mod Sub-Module Model Serial Hw Status
0 Centralized Forwarding Card WS-F6700-CFC SAD082305H5 2.0 PwrDown
Mod Online Diag Status
0 Unknown
Thanx
Sent from Cisco Technical Support Android App
Reza Sharifi
It appears that the module does not power up.  Try reseating the module.  You are also running a very old version of IOS, you may want to upgrade. If these do not help, than open a ticket with TAC and RMA the module.
Thanks Reza .. okay then let me update the IOS and see ..
