sfp+ problems, not working
valerius14
installing tranceivers on isr4331 router, precisely tranceivers model: GLC-LH-SMD I have noticed that the only tranceivers that work are those made in China, i hame same transceiver GLC-LH-SMD made in malaysia but they don't work.
why do only transceivers made in China work even though the transceivers are of the same model?
os version on router isr4331 is ios 17.06.05
6 Replies 6
M02@rt37
Hello @valerius14,
this remind me this bug: https://bst.cisco.com/bugsearch/bug/CSCwe68724
Best regards
ok but I don't think the final solution is use only adapters made in China. I have 12 transceiver made in malaysia and I don't have enough sets of keys to use them as key rings.
Cisco transceivers?
yes, all transceiver are cisco, all same model "GLC-LH-SMD", transceiver made in china works, transceiver made in malaysia don't works
I would think Cisco would be willing to replace the defective transceivers.
valerius14
the error messages on router when tranceiver GLC-LH-SMD are plugged in:
ASR920 %TRANSCEIVER-3-CHECKSUM_ERROR: C0/0: iomd: Detected in the transceiver module in GigabitEthernet0/0/1, module disabled
ISR4331 %TRANSCEIVER-3-INIT_FAILURE: C0/0: iomd: Detected for transceiver module in Gigabitethernet0/0/2, module disabled
