Hi All,
i have 2 issue with my Nexus 3548
1- when i insert GLC-SX-MMD into Nexus 3548P-10G port i got SFP vendor not supported if i check the interface however this is the original CISCO SFP and at the same port the 10G SFP+ from Cisco is working fine , and i am already tried the speed 1000 on this interface , and when i configure the command to allow third party SFP the link goes up , any advice regarding this
Ethernet1/14
transceiver is present
type is 1000base-SX
name is OEM
part number is GLC-SX-MMD
revision is A0
serial number is SP1404025173
nominal bitrate is 1300 MBit/sec
cisco id is --
cisco extended id number is 4
SFP Detail Diagnostics Information (internal calibration)
Current Alarms Warnings
Measurement High Low High Low
Temperature 36.01 C 80.00 C -20.00 C 75.00 C -15.00 C
Voltage 3.19 V 3.59 V 2.79 V 3.50 V 2.90 V
Current 0.00 mA -- 15.00 mA 1.00 mA 13.00 mA 2.00 mA
Tx Power N/A -- 0.00 dBm -10.00 dBm 0.50 dBm -9.03 dBm
Rx Power -30.00 dBm -- 0.00 dBm -26.98 dBm 0.50 dBm -26.98 dBm
Note: ++ high-alarm; + high-warning; -- low-alarm; - low-warning
switch(config-if)# sh int ether 1/14
Ethernet1/14 is down (SFP vendor not supported)
Dedicated Interface
Hardware: 100/1000/10000 Ethernet, address: a0ec.f97d.aed5 (bia a0ec.f97d.aed5
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec
Encapsulation ARPA
Port mode is access
Full-duplex, 10 Gb/s, media type is 1G
Beacon is turned off
Input flow-control is off, output flow-control is off
Rate mode is dedicated
Switchport monitor is off
EtherType is 0x8100
Last link flapped never
0 interface resets
30 seconds input rate 0 bits/sec, 0 packets/sec
30 seconds output rate 0 bits/sec, 0 packets/sec
Load-Interval #2: 5 minute (300 seconds)
input rate 0 bps, 0 pps; output rate 0 bps, 0 pps
RX
0 unicast packets 0 multicast packets 0 broadcast packets
0 input packets 0 bytes
0 jumbo packets 0 storm suppression bytes
0 runts 0 giants 0 CRC 0 no buffer
0 input error 0 short frame 0 overrun 0 underrun 0 ignored
0 watchdog 0 bad etype drop 0 bad proto drop 0 if down drop
0 input with dribble 0 input discard
0 Rx pause
TX
0 output packets 0 bytes
0 jumbo packets
0 output errors 0 collision 0 deferred 0 late collision
0 lost carrier 0 no carrier 0 babble 0 output discard
0 Tx pause
2- second issue : i connect the 10G to the core switch 4503 and another link to another edge switch from Cisco
the link between core and nexus is trunk and there is already vlan interface configured on each one and another access link between the nexus and the cisco edge switch , i can ping from nexus to the edge switch and also can ping from core to edge but the problem that i am not able to ping from core to nexus and vise verse , how ever when i make debug ip ICMP on nexus and ping from core to nexus i can see packets come from core to nexus also i can find the core by using show cdp on nexus
very confusing appreciate any help
