problem connexion ssh 2960 plus 48 PST-L in ssh
admin.rsa
could you explain why with a 2960 plus 48 PST-L with ios 15.0.2.se7, i can't connect in ssh ?
Valérie
glen.grant
Is it setup for ssh ?  Does the switch have the crypto version of code on it that will support ssh ? Have you tried telnetting in to see how things are setup ?
in Telnet is ok immediately, in ssh it's ok now, i must wait few seconds. I try with modulus 1024 or 2048, it's same result
Hi all,
We still have the problem.
SSH connection is very slow, arround 20 seconds for login and after for password !
Configuration working fine with 2960, only 2960+ have the slow ssh connection problem !
Does anyone use this equipments whit ssh ?
If yes, do you have the same trooble ?
