SFTP configuration cisco catalyst c1000
R1nzler
Hey guys
im trying to configure the sftp on a cisco c1000
i followed the documentation
however when I execute the wr it shows no erros, in switch logs shows nothing
everything is OK with username a password for the sftp user
everything is enabled
firewall is allowing all traffic
from the switch i can ping the destination
what im a I missing
thank you for your help
Mark Elsen
  - Use this documentation as a reference : https://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst9300/software/release/16-10/configuration_guide/sec/b_1610_sec_9300_cg/configuring_ssh_file_transfer_protocol.html#task_s31_gwz_3fb
   and or tryout the mentioned examples too ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
R1nzler
i used the cisco 1000 documentation but its the same command and does not work
           - Post screenshot(s) of commands tried and the output ,
 M.
       Beauty and terror
      Just keep going
       No feeling is final
