10-20-2021 01:52 PM
Hello community.
This is my first post and I hope someone may be able to assist me. I have a Cisco SG 200-26P switch which is in a domestic setting. The switch is located in a cabinet in my garage and is therefore connected via a ethernet over main adapter and then subsequently plugged into my home router which manages DHCP.
I can access the switch etc without any issues having assigned it an IP in the same domain as my main switch (192.168.1.x).
I have a PoE camera connected to the switch, however according to my home router, that is being served an IP of
10.100.1.101. For the life of me, I cannot seem to get it on the same port range as all the other devices when they are issued a DHCP address. The router has been fully updated and factory reset, can anyone assist what i may be doing wrong please.
Thank you very much,
Steve
10-20-2021 02:36 PM
If you Looking to have same network, you need to disable DHCP on SG200 Switch ?
So the switch become only Layer 2 and all the DHCP assingment will be from your Home Router.
If you looking to manange the switch, allocate same IP range free IP to switch to manage the device ( 10.100.1.X)
10-21-2021 12:32 AM
which brand/type/model is the PoE camera ? It might just be that it picks up an IP address from a neighboring wireless router (one of your neighbor's possibly).
