04-11-2017 07:17 AM - edited 03-08-2019 10:10 AM
We have a site to site 1gb Ethernet link no termination devices for Q-in-Q.
How do I setup Q-in-Q on a pair of these devices so that all of our VLANs can pass through the link. I have found information on how to set it up if the service provider has terminated the link. I have also looked at the standard Cisco model but unfortunately most of the commands do not work on these devices. Some advice or pointers as to best to approach this please.
04-11-2017 08:07 AM
Please check this link, it could be useful:
https://supportforums.cisco.com/discussion/12943541/sg300-q-q
04-11-2017 08:31 AM
Cisco 300 series datasheet says it's supported.
Q-in-Q VLAN |
VLANs transparently cross a service provider network while isolating traffic among customers |
http://www.cisco.com/c/en/us/products/collateral/switches/small-business-smart-switches/data_sheet_c78-610061.html
CLI
switch(config)# vlan n
switch(config-vlan)# name Q_in_Q vlan
switch(config)# interface id
switch(config-if)# switchport mode customer
switch(config-if)# switchport customer vlan n
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/CLI_300.pdf
GUI page 197
http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
Please rate/mark answer as correct if it is helpful to benefit others. Thank you.
04-11-2017 09:00 AM
HI Philip,
enable
configure terminal
enable password
Creating of vlans
vlan 10
name IT
vlan 20
name Accounts
vlan 30
name Sales
Configuration of trunk ports
interface gigabitethernet 10
switchport trunk allowed vlan all
configuration of Switch virtual interface
interface vlan 10
ip add x.x.x.x/subnetmask
can you please check these commands .
If it is possible please share your remote session so that I will you on this .
CRaju
04-11-2017 03:57 PM
CRaju,
Thanks for your response,
The command "switchport trunk encapsulation dot1q" does not work on this switch
