SG200-50 50-Port Gigabit Smart Switch only getting 200Mbits through put on ports
SND Patheon
Good Afternoon,
We have just purchased a new SG200-50 50-Port Gigabit Smart Switch , I`m unable to get any more than 200 mbps throughput on any of the data ports, I have tried Multiply devices on the switch
with no luck , any ideas ?, this is advertised as a Gigbit switch.
kindest regards
Adam
blandekic
Next time you pose a question provide more details please as I can only guess at this point.
The factsheet says this switch can support 100 gbps total throughput and that it has 48 gigabit Ethernet ports.  Did you set all the ports to the correct speed ("speed all 1000 full-duplex" command)?  Are you using proper cables?  Do the other devices support gigabit speeds?
Hi Blandekic,
I seem to have over come the problem with the Cisco switch , Having upgraded both the firmware and Boot Image , I am now getting approximately Mbps 900 + , many thanks for looking into the problem.
Kindest Regards
Adam
