SG200 configuration
stephenstown20
Level 2
Level 2
hello
I have been tasked with migrating users off an SG200-18
there is only a GUI for management
Am I correct in saying the VLAN ID defined in the column Administrative PVID is the native vlan on the Trunk port ?
7 Replies 7
@stephenstown20
Yes, as long as the option "admit Untagged Only" which characterizes Native Vlans.
hello
thank you for your reply
does the screenshot below clarify the config ?
[cid:68affeca-0dc2-45a8-be16-ee5d4d3f9cfe]
@stephenstown20
 I can not see the screen. Only a string
please see below & thank you again for your help
[cid:6a425f8d-4a52-4c1f-938f-0b00d0a50609]
Not coming. See only string
please see attached
Select one of those interface and go to edit. Dont change anything but check if "admit Untagged Only" is checked.
If this option is checked then the VLAN is acting as Native vlan as no tag will be added to the frame.
