sg250-08 network switch will be able to use the dynamic IP address?
mxl
Hello! sg250-08 network switch will be able to work the dynamic IP address? work without a static ip address.
Thank you
pman
yes.
IPv4 routing
Wire-speed routing of IPv4 packets
Up to 32 static routes and up to 16 IP interfaces
Layer 3 interface
Configuration of Layer 3 interface on physical port, LAG, VLAN interface, or loopback interface
https://www.cisco.com/c/en/us/products/collateral/switches/250-series-smart-switches/datasheet-c78-737061.html#Productspecifications
Richard Burts
I found this statement mentioning use of dynamic addressing in the sg250 switch "When the switch is using a DHCP server-assigned IP address" in this document "https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf_sg250/quick_start/guide/en_US/78-100762-01A0.pdf" if you want additional details.
Rick
pman
yes.
IPv4 routing
Layer 3 interface
mxl
Thank you all!
