SG250X-48P login not possible
powerstat
Hello I have a SG250X-48P since some years.
I updated it from 2.5.5.x to latest version 2.5.9.54.
After this update I had a problems with performance.
So I decided to go back to the backup image 2.5.5.x but after this I could not login anymore.
So I did a factor reset - which allows me to login via cisco/cisco.
After this I uploaded the 2.5.9.54 image again.
The result ist that I could not login any longer - also not after a factor reset.
The Web Interface ist still available at 192.168.1.254 but when entering cisco/cisco it only says Processed 10% and then jumps back to the empty login mask.
I have tried to switch it off/on and multiple factory resets without luck.
Any chance to reactivte the switch? Is there a console port inside when I open the case? Or any other tricks?
10 Replies 10
marce1000
   - There have been reports like this when an upgrade was done on these devices and the password contains special characters (CORRECTED)
   M.
marce1000
    - For instance checkout : https://community.cisco.com/t5/switches-small-business/update-to-2-5-8-12-login-problem/td-p/4463118
   M.
Sorry, because of the factor reset the password and user should be "cisco", so no special character problem.
 - @powerstat   That is true, there is one technical security point to think about ; what does the device think about
                         upgrades with the default password and what does it do; it's  perhaps going too far  but have a try
                         by using another simple username and password after the first factory reset, then upgrade and check
                                                if those simple credentials  (not  cisco/cisco) are still working ,
  M.
@marce1000But how should I do that - there is no way in for me anymore - looks like my sg250x-48p is bricked.
  - @powerstat   I can't see any solutions for the current situation neither,
  M.
marce1000
  - @powerstat  Something else  I was thinking about ; is the phenomenon the same with different browsers
                         (to exclude obscure caching effects) ?
  M.
@marce1000That was an interesiting hint - with firefox I had no login at all - now I tried chrome - with logs me in let me set a username and password and then hangs at processing 40%.
But looks as login with chrome and the new user/passwd works. Active image now is the older 2.5.5.47
 @powerstat  I assume it would be safe to do the upgrade again. If you can't login use Chrome in Incognito Mode
 M.
