SG300 28PP Bridging VLANs in L3 mode
Mar7in
I have been tasked to configure mentioned cisco switch (in work), although I don't have experiences with configuring switches I have managed to do some basic configuration to some extent. Situation is depicted below. We have intranet connection and internet connection, both have DHCP server. Then there is equipment inside vehicle shown as PC, printer and UPS on the picture as local network. This local network should have access to the intranet (mainly the PC). Intranet and internet must be separated. I am accessing the switch via config PC connected by ethernet - unfortunately I don't have CLI access.
I would appreciate help on how to bridge VLANs so that VLAN1 has access to the intranet which is VLAN2 (with DHCP). And VLAN3, which is also DHCP, could access internet. Most posts here on forum related to my problem are older and links posted there do not work anymore.
Here is the current configuration
config-file-header
switch2fcd8d
v1.4.11.5 / R800_NIK_1_4_220_026
CLI v1.0
set system mode router
file SSD indicator plaintext
vlan database
vlan 2-4
exit
bonjour interface range vlan 1
hostname *
username * password *
interface vlan 1
no ip address dhcp
interface vlan 2
name INTRANET
ip address dhcp
interface vlan 3
name INTERNET
ip address dhcp
interface vlan 4
name CONFIG
ip address 192.168.2.1 255.255.255.0
interface gigabitethernet1
switchport mode general
switchport general allowed vlan add 2,4 tagged
switchport forbidden vlan add 3
switchport default-vlan tagged
interface gigabitethernet2
interface gigabitethernet3
interface gigabitethernet4
interface gigabitethernet5
interface gigabitethernet6
interface gigabitethernet7
switchport mode access
switchport access vlan 3
switchport forbidden vlan add 2,4
switchport forbidden default-vlan
interface gigabitethernet8
interface gigabitethernet9
interface gigabitethernet10
interface gigabitethernet11
interface gigabitethernet12
interface gigabitethernet13
switchport general allowed vlan add 4 tagged
switchport general allowed vlan add 2 untagged
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
interface gigabitethernet18
switchport general pvid 2
interface gigabitethernet19
interface gigabitethernet20
interface gigabitethernet21
interface gigabitethernet22
interface gigabitethernet23
interface gigabitethernet24
switchport general pvid 4
interface gigabitethernet25
interface gigabitethernet26
exit
0 Replies 0
