07-13-2021 05:56 AM
i have sg300 with version 1.4.8.6.
it looks like there is some issue with POE configuration, i have unify access point (AC-LR) that power consumption is 6500mw,
* i have 6 of them connected, once i'm connecting the 7th ap port is not coming up.
* the current ap that working are connected n ports (1,3,5,7,9,11), if i'm moving one of them to port 2 (for ex) port is not coming up.
* all ports are configured on the same class and power consumption is:
PoE Power Information on Master Unit
Detail
Maximum Available PoE Power(W): 180
Total PoE Power Consumption(W): 15
PoE Power Mode: Port Limit
Please advice.
thx.
07-13-2021 05:58 AM - edited 07-13-2021 05:59 AM
Look buzzard here, you have only odd ports working, try any odd port than even like 13 instead of 2 ? what is the outcome ?
07-13-2021 08:53 AM
no change, only 6 AP are working. i checked it with additional switch..and nothing...
any idea?
07-14-2021 11:17 PM
any idea how to solve that issue???
