SG350 CLI
Portus92
I rencently bought a Cisco SG350-10 because I just started to learn switching and routing with Cisco.
But the commands I have to use with this switch are a bit "strange" (the author uses a Cisco 2960 in his book).
Is this the future for Cisco switches CLI or is this just some simplifications for SG350 ?
Is there any document where I can find all the differences ? Or should I buy a Cisco 2960 if I plan to study to pass my CCNA ?
Thanks a lot.
luis_cordova
Hi @Portus92
Indeed, your device uses open source software.
Maybe this video can help you a little with that model:
http://www.youtube.com/watch?v=L69R0TRaOmI
For CCNA studies, these are the recommended models:
Reza Sharifi
The SG series products are not really for studying for Cisco certifications. For certifications, you usually want to use the 2960s, 3650s, 3750, 3750x or 3850s, series switches.
luis_cordova
Hi @Portus92
Thanks, I will buy a 2960 🙂
