SG350 IPv6 Routing
edisonjose
hi
Device: SG350
I'm trying to ipv6 intervlan route below is my configuration.
switch2437ef(config)#interface vlan 10
switch2437ef(config-if)#ipv6 address 2001:DB8:2222:7270::2312/64
switch2437ef(config-if)#EXIT
switch2437ef(config)#interface vlan 20
switch2437ef(config-if)#ipv6 address 2001:DB8:3333:7271::2312/64
switch2437ef(config-if)#exit
switch2437ef(config)#interface loopback 1
switch2437ef(config-if)#ipv6 address 2001:DB8:2222:7272::72/128
switch2437ef(config)#ipv6 route 0::/0 2001:DB8:2222:7270::1
switch2437ef(config)#ipv6 route 2001:DB8:3333::/48 2001:DB8:3333:7271::1
From pc, I'm able to ping to the respective vlan ip, but can not ping form PC to PC.
What could be the problem.
Seb Rupik
Hi there,
What mode is the SG350 running in, switch or router?
cheers,
Seb.
Switch mode
Go to Administration > System Settings > System Mode and select 'L3', then reboot the device (page 62 of the attached user guide).
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/administration_guide/78-19308-01.pdf
On the CLI type:
set system mode router
cheers,
Seb.
