SG500X - Inter VLAN routing issue
paul.hermans
Hi, I'm trying to get the inter VLAN routing working on a SG500X switch but with no success. For the test I did a factory reset and created the simplest scenario. See attached drawing
Inter VLAN routing
Here are the running-config, the ip routes and the ip interfaces:
switchf5512c#show running-config
config-file-header
switchf5512c
v1.4.7.5 / R800_NIK_1_4_194_194
CLI v1.0
set system queues-mode 4
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 40
exit
bonjour interface range vlan 1
hostname switchf5512c
ip ssh server
interface vlan 40
name Office
ip address 192.168.40.11 255.255.255.0
interface gigabitethernet1/1/13
switchport mode access
interface gigabitethernet1/1/14
switchport access vlan 40
interface gigabitethernet1/1/15
exit
switchf5512c#show ip route
Maximum Parallel Paths: 1 (1 after reset)
IP Forwarding: enabled
Codes: > - best, C - connected, S - static,
R - RIP
D 0.0.0.0/0 [1/2] via 192.168.100.1, 02:13:35, vlan 1
C 192.168.40.0/24 is directly connected, vlan 40
C 192.168.100.0/24 is directly connected, vlan 1
switchf5512c#show ip interface
IP Address I/F I/F Status Type Directed Prec Redirect Status
admin/oper Broadcast
192.168.40.11/24 vlan 40 UP/UP Static disable No enable Valid
192.168.100.11/24 vlan 1 UP/UP DHCP disable No enable Valid
IPv4 routing is enabled (in GUI)
The firewalls on the hosts is turned off.
What is the result:
From host 192.168.100.12 I can ping the VLAN 1 interface (192.168.100.11), the firewall (192.168.100.1) and I have internet access. I cannot ping the VLAN 40 interface (192.168.40.11) or host 192.168.40.12
From host 192.168.40.12 I can ping the VLAN 40 interface (192.168.40.11). I cannot ping VLAN 1 interface (192.168.100.11)  or host 192.168.100.12.
From the CLI I can ping everthing (192.168.100.12, 192.168.100.11, 168.168.100.1, 192.168.40.11, 192.168.40.12).
What am I overlooking? Please help!
Diana Karolina Rojas
It looks like a correct configuration. Can you prove a tracer from one user in a vlan to another user in other vlan? where does the tracer stop?
A trace route from host 192.168.40.12 to host 192.168.100.12 stops after the first hop (192.168.40.11). First hop 1 ms, 4 ms 3 ms. After that nothing but "Request timed out".
A trace route from host 192.168.100.12 to host 192.168.40.12 stops at the first hop. Nothing but "Request timed out". However, the log of the firewall shows that the ping arrived there (192.168.100.1) and were logged because of a policy violation. That's normal because there is no policy for routing to VLAN 40.
Hello again!
Did you prove create another vlan? Maybe is a problem with vlan 1, the configuration is complete? aren't there access list configured, firewall features or so on configured in your switch?
