SG550XG-8F8T accessing GUI stuck at 'processing data 50%'
Romein
Since a while I can't access my switch anymore via the GUI. It is stuck at 40-50%.
I did update the firmware to image_tesla_cbs350_hybrid_2.5.7.85 but that didn't change anything.
I can connect to the switch via telnet.
Latest months I could access the switch via GUI but the connection did freeze every minute for a few seconds.
Don't know if that has anything to do with it.
11 Replies 11
pieterh
as first step you could clear your browser cache
didn't work
balaji.bandi
are you trying with hostname if so, try with IP address let us know how it goes.
BB
I always login with the ip-address.
after upgrade it was broken, then looks like some bug here.....may be contact SMB tac for help.
BB
It was broken before upgrading the firmware. That's why I tried that. Any idea how I can contact SMB?
Thanks, I'll contact them en keep you all updated!
Hm, I see I need a service contract for that. I don't have one anymore. The switches are about 5 years old.
These device more rely on GUI config, if you could reset to factory and check if that is better.
BB
This switch is in a production enviroment (school) so I can't just try something new. It will have to wait till next holidays...
As long as it doesn't crash too often I can live with it.
