SGE2010P VOIP QOS IP Based ACL
timjeens1
Hi Guys,
Slowly trying to figure out how to set up QOS on this switch.
But not really sure how to set up the IP Based ACL for VOIP traffic.
I have given it a Name (VOIP), with a priority of 1.
There is a big list of Protocols now to select from, but I do not know which to select..
ICMP, IGMP, IP, TCP, EGP, IGP, UDP, HMP, RDP, IDRP, IPv6, IPv6:Route, IPv6:Frag, IDRP, RSVP, and AH
Can anyone help set up this page (attached)
Or at least let me know which protocol to select.
-Tim
cadet alain
Voice data use RTP+UDP and voice signaling can be SCCP( TCP) or SIP(TCP).
Regards.
Alain.
Hi Alain,
Thanks for the reply, RTP isn't in the list but UDP is, is there a specific port, or would any do?  also for the SIP(TCP)?
and whats the difference between Voice Data and Coice Signalling?
-Tim
