Sh int output
Ibrahim Jamil
Level 6
Level 6
Hi Folks
Pls See the below output,how to troubleshoot what is going on there,in order to catch why this drops
GigabitEthernet1/1 is up, line protocol is up (connected)
  Hardware is C6k 1000Mb 802.3, address is 0065.a88b.448f
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Full-duplex, 1000Mb/s
  input flow-control is off, output flow-control is off
  Clock mode is auto
  Last input never, output 00:00:55, output hang never
  Last clearing of "show interface" counters 1y12w
  Input queue: 0/2000/23/0 (size/max/drops/flushes); Total output drops: 30
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 11000 bits/sec, 5 packets/sec
  5 minute output rate 513000 bits/sec, 82 packets/sec
     3340179492 packets input, 1118995307814 bytes, 0 no buffer
     Received 132532351 broadcasts, 0 runts, 0 giants, 0 throttles
     23 input errors, 15 CRC, 15 frame, 0 overrun, 0 ignored
    6401145698 packets output, 8036777723276 bytes, 0 underruns
     30 output errors, 0 collisions, 0 interface resets
     0 lost carrier, 0 no carrier
     0 output buffer failures, 0 output buffers swapped ou
abhischa
I see a counter value of 15 for CRC errros. Is this counter increasing? If yes, we need to check at L1 - the physical connections. Swap the cable with another one or swap SFP's if any are present.
CRC increments point to a physical layer issue and will lead to drops.
Cheers,
Abhishek.
Pls rate helpful posts.
what about the Below:strange Brodcast
Received 132532351 broadcasts, 0 runts, 0 giants, 0 throttles,
How to verify and Troubleshoot
