03-20-2013 12:48 PM - edited 03-07-2019 12:23 PM
I am building a network in a lab envrionment to mimic a new production configuration we are implementing. I don't know if this is the normal way show ip bgp displays the paths to a network.
See attached pdf for a diagram of the network.
my issues is if advertise 10.128.3.0/24 network from FMT-SWITCH-1 and that prefix goes out to both MPLS providers and is then received by
GDC-ROUTER-3 and GDC-ROUTER-4.
If I go to GDC-SWITCH-1 and look at the output of show ip bgp 10.128.3.0/24, I only see the path's that point to one MPLS carrier:
GDC-SWITCH-1#sh ip bgp vpnv4 VRf VPN_A 10.128.3.0 255.255.255.0
BGP routing table entry for 64770:30:10.128.3.0/24, version 447
Paths: (2 available, best #1, table VPN_A)
Multipath: eiBGP
Not advertised to any peer
209 65534
10.99.8.50 (metric 409600) from 10.99.8.50 (169.254.0.1) GDC-ROUTER-4
Origin IGP, metric 0, localpref 110, valid, internal, best
Extended Community: RT:64770:300
mpls labels in/out 37/nolabel
209 65534, (received-only)
Should I also see the paths that are being received from GDC-ROUTER-3 as well?
I can provide more detail if necessary.
thank you,
Matt.
03-21-2013 05:24 AM
I'm a bit rusty, but as no one else has responded, thought I'd try to help.
Please confirm that GDC-ROUTER-3 is definitely advertising the 10.128.3.0/24 prefix out to the GDC-SWITCH-1 neighbor?
Is either device filtering prefixes at the moment, and in which direction?
I'm presuming the BGP neighborship is established between GDC-ROUTER-3 and GDC-SWITCH-1
03-21-2013 07:31 AM
Hello Matt,
you have manipulated the Local preference BGP attribute that is 110 somewhere in your setup.
As a result of this manipulation the best path choice performed by GDC-ROUTER-4 has propagated in the whole AS. If GDC-ROUTER-3 prefers the route coming on iBGP from GDC-ROUTER-4 it will avoid to advertise the other eBGP advertisement.
I think this is what is happening here.
Hope to help
Giuseppe
